I am rubbish at amp stuff...............
I have a 70's valve head that instantly blows the Mains fuse as soon as you switch it on, what could be the most likely cause?
As what is indicated on the chasis, the Mains fuse is 2 amp and the HT fuse is 1 amp
Interestingly I have another one of the same amp that works perfectly, weirdly I just checked the fuses against the recommened printed on the chasis and on this one it has a 500MA anti surge fuse on the HT and a 3 Amp fuse on the mains...............
Any help would be great, I have no idea about any of this stuff the only thing I am good at is giving myself electric shocks. :-)
Old Is Gold
Its an old STAK head like a Hiwatt kinda thing
Yeah there is a standby switch and a power switch.
As soon as I switch on the power switch the power light goes on for 1 second then goes out, when I then check the fuse its blown.
Well, the chassis in the picture rates a 2amp mains fuse but it also has an internal voltage selector. Might it have been set down to 115V for the US at some point?
Dave.
Firstly the switch was definitely on 240v
I removed the power tubes which to be honest are pretty much brand new Svetlana EL34's and the thing still blew the fuse.
I remembered what happened to this amp now as it was actually serviced about 4 years ago by a tech, I used it to record an album with my band and everything was cool then I lent it to my friends band and that it was it never worked after that.
Here is a pic of the inside, it doesn't look too bad.
I am just going to have to sell it as spares or repair I guess.
I just dont know if I can be arsed to deal with these amps anymore, I have my matamp and the STAK that works which will do.
Ill probably whack it on ebay as spares when I get back from france.
I want to get rid of the 230 watt anyway as it is bloody heavy and I am never going to use it.
That one works but clearly all the power tubes need to be changed, they all light up but two of them are not very strong. Also all of the knobs are very noisy so it needs a very good clean.
All the pots are crackling and it needs a good clean.
They are actually really amazing sounding amps similarish to Hiwatt's but not as good.
I am going to ask for about £300 for it collection from London
It is fucking heavy though.
