Greetings folks,
I have, hopefully, a straightforward question to those of you who finish instrument bodies. I have a few bottles of Createx Auto-Air water-based paints that I'd bought several years ago with a view to spraying guitar bodies. Without the need for full-on nitrocellulose-proof gear. I figured water based would be easier..... However, whilst I am happy to give the spraying a go (from iridiescent/flip-flop colours to flourescents using a touch-up gun), I am unsure what would be the best topcoat to use.
Obviously, the key is to try things out first on a little scrap - so far some clear nitro from Steve Robinson over a couple layers acrylic (I think it is) iridescent blue. How long would you leave different finishes to sit for before accepting that they are compatibile?
Thoughts?
Adam
With w/b it's very unlikely a solvent-based clearcoat will wake it up & react etc, in the same way you can get reactions putting solvent paint onto solvent paint.
Normally you don't want a paint going onto a shiney one, when there's no bond between the two like when nitro melts into nitro say. The w/b I have used soaks up clear like a sponge, a different type of paint though.
