Kill Switch Recommendations?
WonkyWonky Frets: 188
I want to fit a reverse Kill switch to a guitar.  That is an off/on switch to activate the kill switch via a push pull on the tone control and then a normally off push switch that will sound when pressed (SPST-NO).  I ordered one off Amazon which I've had to return as it was way to small and way to hard to press.
So just to be clear once the circuit is activated by a push/pull switch the guitar would be silent until the momentary button is pressed and then sound will be made.
I need a momentary switch the right sort of size and the right sort of pressure to activate.
There are many different switches that look like they may do the job, but it's hard to tell without having them to hand.  I notice that a fair few of them don't seem to have enough thread to go through a guitar body, which is also an issue.
Anyone tried to do something similar?  Any suggestions?
  • meltedbuzzboxmeltedbuzzbox Frets: 10340
    Foot pedal?
  • WonkyWonky Frets: 188
    Foot pedal?
    It's got to be guitar mounted for me I'm afraid.
  • bbill335bbill335 Frets: 1401
    have you tried using a low-torque pot and a compressor/gate thing? are you going for morello-esque effects?
    Not tried this TBH.  I don't think it'd be quick enough for what I'm after. Also have to be a bit careful with a Noise Gate changing the tone of the note.  If I understand you right that is.  Would that even be accurate enough?
    Good suggestion though, I've never heard or thought of it before.  Can you elaborate a bit more on how this works, just to make sure I understand what you're getting at?
  • FunkfingersFunkfingers Frets: 14800
    Wonky said:
    Foot pedal?
    How about an externally mounted box, like Les Paul’s Paulverizer?
    My experience with Shadow kill switch pots is that they fail far sooner than their price might lead you to expect.
    Wonky said:
    Foot pedal?
    Aah now, I'm not thinking of using a pot as a shadow kill switch, just an off/on for the actual push switch/circuit, if you catch my drift.  A proper sprung off/on switch for the actual business end of things with a separate push/pull on the tone to activate the circuit is what I have in mind.  It's the actual push button switch is the thing causing me the problem.
  • OilCityPickupsOilCityPickups Frets: 11147
    Wonky said:
    Wonky said:
    Foot pedal?
    Push push pots have a much shorter life than push pull ones ... they usually fall apart fairly spectacularly with about a tenth of the use that would kill a cheap push pull.
    Wonky said:
    Wonky said:
    Foot pedal?
    I've never used or even thought of a push pot.  By the sounds of it, good job too.
    just rolling the pot really fast, and using a pedal to reduce the "swell" effect to make it closer to an on-off sound. The CTS pot on my strat goes from 0-10 really quick and smooth, the pot has very little resistance.
  • Danny1969Danny1969 Frets: 10601
    edited June 2019
    You could use a normally closed (push to break)  push switch wired from jack hot to earth wired with the switch portion of the tone control in series with the hot .... that would work pretty well.
    I use a little red one from CPC.co.uk
    I'm wondering if one could use an industrial kill switch like I have on my drill press ... those are built to take millions of cycles
  • InactiveXInactiveX Frets: 295
    Or a pinball machine button, perhaps?
    Don’t follow influencers
    Watch the parking meters
  • joetelejoetele Frets: 957
    Wonky said:
    Foot pedal?
    I've just realised that the killswitch pedal I've got could quite easily be mounted (velcro maybe) to the guitar as it doesn't require power. Hmmmm
    MUSIC: Pale Blurs
