SOLD Stone Deaf FX PDF-1 Distortion
denz32denz32 Frets: 17
edited May 2014 in FX £
My Stone Deaf FX PDF-1 Distortion is for sale! £90 plus postage.
For anybody that hasn't heard of it before... It is a parametric EQ that has a switch-able clean and distorted circuit inside which enables the user to cut and boost by 20dB of a selected frequency from 65Hz-3000Hz. It has a selectable 5 position bandwidth switch that tailors your sound from FAT to Thin which will give you FAT bottom end and THIN needle point highs on your guitar and bass. Kick in the overdrive/fuzz and you can select a multitude of sounds that can get you from dirty overdriven /fizzy guitar fuzz to fizzy velcro type bass fuzz that also has a lot of colour in between. It was based on the Maestro Parametric Filter MPF-1 that was designed by Bob Moog back in the 1970's for Gibson Norlin. This original pedal is used by Alex Lifeson of Rush and perhaps more notably Joshua Homme of Queens Of The Stone Age (Its all over the rated R album).
Filter height & frequency control
5-way rotary bandwidth switch
Clean/dirty switch
Input, output & aux output sockets
Power: 9V battery or 9V DC mains adaptor (Boss Style)
Dimensions: 80(h) x 112(w) x 150(d) mm
http://i1374.photobucket.com/albums/ag420/deanclemmett32/pdf12x_zps1f2bc8f8.jpg
