WITHDRAWN ALL. Boss GT001 125 Keeley Tone station 190 Amplifi TT 50 Alterego V4 100
BlaendulaisBlaendulais Frets: 3346
edited June 2019 in FX £
The GT-001 packs the acclaimed amps and effects of the GT-100 Version 2.0 in a stylish desktop processor for your home studio or mobile rig.
In addition to the guitar input, an XLR mic input is included for capturing vocals or acoustic instruments, and the built-in USB audio/MIDI interface provides a direct connection for creating music with your favourite DAW.
Power from USB when using with PC - mains adapter not included
It functions as a four-in/ four-out audio interface that will let you record your dry guitar sound simultaneously with the processed sound
https://www.dropbox.com/s/7xnpjkeqvmav2rw/Boss.JPG?raw=1
  • BlaendulaisBlaendulais Frets: 3346
    The Amplifi TT is a table top device - works with the Amplifi Remote app to give you wireless access to unlimited amounts of guitar tones from within the app
    You can stream music from your library through the same channels and jam along with tones that can be selected to match up with the song! There is a headphone output is you want more private sessions and there are comprehensive connections on the back for USB, 1/4”, RCA and TOSLINK outputs.
    https://www.dropbox.com/s/5ttx7e25yxvjhfa/Amplifi.JPG?raw=1
    Emulations of some of the best echoes committed to tape. Carefully replicated vintage echo presets, including the likes of the Binson Echorec, Roland RE-201 Space Echo and Watkins Copicat.
    • 7 seconds of delay
    • 3 User Programmable Preset Switches
    • Tap Tempo
    • 40 Second Looper with Undo
    • MIDI In and Thru
    • Expression Pedal Input, MIDI, USB
    • Stereo Input/Output
    • Switchable True or Buffered Bypass
    • 9.25” (23.49 cm) x 5.375” (13.65 cm) x 2.25” (5.71 cm)
    • 9vDC/300mA (No Batteries)
    https://www.dropbox.com/s/k8xkh17dohw5xrf/TC.jpg?raw=1
    • Compression / Boost / Overdrive / Distortion
    • Drive Section controller for Level, Drive and Tone
    • Toggle switch for switching between Baked and Mod+ Drive modes
    • Drive / Boost section controller for Level, Tone and Drive
    • Toggle switch for switching between 1962 & "Katana"” Drive / Boost modes
    • Compression section controls for level, glare and sustain
    • Toggle switch for switching between "Treble" & "Stock" compression modes
    • 3 bypass footswitches, one for each section
    • True bypass
    https://www.dropbox.com/s/ltlqjvw7262fd5j/Keeley.jpg?raw=1
    bump
  • daviesjdaviesj Frets: 27
    How much is the keeley?
    All available
    Still here
    Withdrawn
