can you make a pot's action looser?
either by dismantling or spraying something inside?
I like them really light touch
  • ICBMICBM Frets: 73027
    Try spraying a lot of contact cleaner in. That often makes them looser whether you want it to or not...
  • steamabacussteamabacus Frets: 1276
    Contact cleaner will loosen them up but I find they can stiffen up again quite quickly afterwards. I like to use Servisol contact cleaner first and then follow up with some spray vaseline which I posted about some years ago here ...
  • mrkbmrkb Frets: 7032
    Isn’t the resistance caused by the grease on between the back of the rotary disc damping the torque against the rear casing? If so just take the back off and remove some of the grease.
    Karma......
    Ebay mark7777_1
  • citizen68citizen68 Frets: 172
    Spend 5 or 10 minutes rotating the pot quickly between min & max position - usually works
    Seemed like a good idea.....
  • fretmeisterfretmeister Frets: 24843
    Swap them for Bourns Low Friction pots.
    They are usually under the EVH brand in the UK.
    I've got one in my strat and it is way easier to move
    https://www.andertons.co.uk/guitar-dept/electric-guitar-accessories/electric-guitar-parts/evh-low-friction-500k-pot
    They come in 250 and 500
  • guitargeek62guitargeek62 Frets: 4240
    ^ or buy PRS pots too, virtually no resisitance on those!
    Might be a silly question, but is there any way to do the opposite? I.e. I have a tone pot that had barely any mechanical resistance, is there any way to add any?
  • prowlaprowla Frets: 5007
    Take off the knob, put a small disc of foam over the spindle, put the knob back on.
  • RolandRoland Frets: 8846
    Alternatively an O ring
    Use Servisol “Super 10”. It’s a contact cleaner + lubricant. It’s managed to loosen up every pot I’ve used it on with just a small dose.
