tiny solid state amp head
samzadgansamzadgan Frets: 1471
So, I want a small solid state head that i can use with a cab, but also with headphones.
I could get a valve head, but i want solid state so that I can run it without connecting up to cab.
I've been looking at Micro Terror, but hear the headphones aren't great, but then i remembered the Crate Powerblock, and it has simulated headphone output.
Has anyone played one of these...i've read mixed reviews
i would use it clean and as pedal platform...a lot of the time with headphones.
  • dindudedindude Frets: 8630
    One if these may suit, they are tiny, and sound pretty good from the various clips.
  • steamabacussteamabacus Frets: 1292
    Not quite released yet and maybe a bit more complex than you're after? Look neat, though....
    http://bluguitar.com/english/AMP1.html
  • Does it need to have a preamp and power amp, or would seperates work?
    Seperates - an EHXTortion or an AMT series 2 pedal, and an ISP Stealth?
    All in one, there is a Randall one maybe?
  • Not quite released yet and maybe a bit more complex than you're after? Look neat, though....
    Wooooooow....
    These are all good options...i do want something simple that i can still use my pedals with. That hotones look good, gotta check out reviews of the headphone quality.
  • Blackstar ID Core?
  • ecc83ecc83 Frets: 1747
    If you really wanted a valve PA stage the Blackstar HT series can run as a pre amp and give you both a "clean feed" from the FX out or an emulated output.
    Ah! Just seen "headphones"! Got to be the HT-5 then. OR! as you were and a 20quid Behringer headphone amp? Then you could hook in  3 mates!
    Dave.
  • robinbowesrobinbowes Frets: 3121
    I've got one of these which I don't use much any more:
    Great sound through a "proper" cab. Awesome Marshall crunch sounds.
    PM me if interested.
    R.
  • p90foolp90fool Frets: 32394
    ZT Lunchbox? Not just a head, but just as small and a handy thing to have around.
  • downbytheriverdownbytheriver Frets: 1089
    Blackstar HT1R - I use one as a preamp all the time. Same output takes headphones - quarter inch jack.
  • ICBMICBM Frets: 74495
    Avoid the Crate. They sound terrible - through a cab as well - and are unreliable. Personally I also think the Micro Terror sounds terrible too, but I know some people like them.
    Maybe try the Marshall MG15 head (which comes with the micro stack, not sure if you can buy it separately though) - they're surprisingly good and very cheap.
  • Flanging_FredFlanging_Fred Frets: 3197
    If you're quick you could enter the fretboard challenge #2 and win one of those little diago heads ( or did that finish already?)
  • midlifecrisismidlifecrisis Frets: 2348
    I thought my micro terror headphone output was harsh and tinny, until I tried a decent set of headphones on it now its just harsh but not tinny. what im saying is the headphones make a huge difference
    lol
    And true!
    so...headphone's is a big criteria as is being able to use it without a speaker load...so unfortunately no valve heads would work.
    the little smasher is nice, if it had a headphone jack, that would be it!
    thanks @ICBM, i like the idea of the little marshall head...but yeah it might be difficult to buy the head on its own...unless someone wants 2 1x12's and i can split the purchase!...but will keep an eye on that one.
  • JalapenoJalapeno Frets: 6464
    This.  They're great - can play through headphones, and have 200W ready if needed.
    Feedback
    i did find a few crate's on ebay, but they are all over £100…not sure i would want to spend that much on it.
    Micro terror is cheaper…but the headphones issue is a big one.
    Still keeping an eye out for one of those marshall mg15 heads…but thats near impossible.
    those hotones look ok…any experience with the headphone jacks?
