Also if you have an existing nut with good spacing you can clamp that with a blank and use it to slot the blank to copy it's spacing.
Just sayin
(formerly customkits)
Essential bit of kit
For those I use the calculator on my website, transfer the measurements to Inkscape and print onto a sticky label.
I stick the label to the nut and cut through the lines using a razor saw to make the starting slots.
https://i.imgur.com/jVnSX3m.jpg
https://i.imgur.com/bl3QqTO.jpg
