Wraparound Bridge - Longer Saddle Travel (Wider Intonation Adjustment)
Excuse the crap pic quality...
https://i.imgur.com/69mq3yc.jpg
Can anyone recommend a bridge with longer saddle travel re. intonation adjustment?
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • ICBMICBM Frets: 72954
    I'm assuming you need it longer in the forward direction, since you can get huge travel backwards by using the two large screws...
    If so I think the TonePros one does.
  • I’d been thinking about one of these Vox Maxconnect jobs...
    https://i.imgur.com/mQDXWsS.jpg
  • Is it definitely the saddle travel range that you require?
    The OP photograph appears to illustrate a bridge/tailpiece unit that is not ideally suited to the stud positions.
    Schaller and BadAss spring to mind.
  • Schaller 455 or 456 might do it? @ICBM @Funkfingers ;
  • Is the OP photograph an actual guitar on which you are working or an image file that you borrowed just to illustrate your question?
  • DanielsguitarsDanielsguitars Frets: 3308
    i think a schaller signum is one of the longest travels I've come across maybe 9mm from memory, I'm sure others will know more than me
    www.danielsguitars.co.uk
    (formerly customkits)
  • FunkfingersFunkfingers Frets: 14725
    edited September 2019
    Probably insufficient travel, given the stud placement issue.
    Same goes for the Signum.
    If that cannot rescue the situation, nothing will.
  • p90foolp90fool Frets: 31886
    If you're really stuck and don't want to redrill and refinish it's not a massive engineering job to turn up some eccentric offset studs.
    Getting absolutely dead on height adjustment will depend on the thread pitch though as you'll have to set them in a forward position, meaning that height adjustment will have to be by one whole turn.
