SOLD Fishman Pro-EQ outboard pre-amp, Neo-D p/u
(1) Fishman Neo-D Single Coil Pickup
Passive Neodymium magnet sound-hole pickup with 80cm of cable terminating in an output jack socket that can be end-pin mounted. (Many Taylor acoustics come with a pre-drilled hole of the correct size.)
In excellent condition.
Because it's passive, you never need to worry about batteries. You should be aware that it can pick up interference just like any other single coli pickup.
Full Fishman spec here, user guide here.
Audio sample of this very pickup here - recorded by yours truly straight into my DAW with just a touch of reverb added.
£30 delivered in UK. SOLD
(2) Fishman Pro-EQ Acoustic Instrument Pre-amp/Equalizer
This is the '90s rectangular-box version, with controls for Volume, Bass, Middle, Treble, and Brilliance, plus a set-and-forget Sub-Bass control. Can be powered from a standard Boss-type 9V supply or a PP3 battery (neither supplied).
Good working order, some paint chips to the metal case. Comes in original (if tatty) box with manual, plus a belt clip for mounting on a strap or belt.
User guide with EQ frequencies
here.
£35 delivered in UK.
![Image: https://i.imgur.com/VDtjZxM.jpg](https://i.imgur.com/VDtjZxM.jpg)
![Image: https://i.imgur.com/TDq3uWc.jpg](https://i.imgur.com/TDq3uWc.jpg)
![Image: https://i.imgur.com/ryBQ96b.jpg](https://i.imgur.com/ryBQ96b.jpg)
![Image: https://i.imgur.com/JHY0ibM.jpg](https://i.imgur.com/JHY0ibM.jpg)
![Image: https://i.imgur.com/IS4Wcfb.jpg](https://i.imgur.com/IS4Wcfb.jpg)
