Higher Value Tone Pot
 I’d like to squeeze a little bit more “brightness“ out of a two humbucker guitar.  Otherwise it sounds rather nice...
I find myself wondering whether increasing the value of the tone pot (from 450K to 500K) will make a difference or do I need to go up to a 1K pot?
Expert opinions deeply appreciated
Jay
  • No matter how good your hearing is, you won't hear any difference between 450 or 500. :)
  • jaymenonjaymenon Frets: 840
     I rather suspected  that.
    I was just hoping that it would make a similar difference to that between 8 and 10 on a tone control...
  • ICBMICBM Frets: 72956
    1M might make a small difference, but still not much. A no-load control would make slightly more.
    But using a lower-capacitance cable, or just shorter, would be at least as effective probably.
  • FunkfingersFunkfingers Frets: 14725
    edited October 2019
    Furthermore, because most of the action is between 10 and 7, the 1Meg tone pot is no fun to use.
    IMO, the only place where a 1Meg pot makes a significant difference is in a Fender Jaguar. It is still terrible to use but, in those guitars, nothing else sounds right.
  • sixstringsuppliessixstringsupplies Frets: 430
    450k-550k - no difference
    500k pot to 1Meg pot - probably a difference, but negligible
    have you tried changing capacitor value or as @ICBM suggests using different cable.
    yes as Gary suggests, I’d even wager no audible difference (to the human ear) between 400k-600k
    For Modders, Makers, Players
    https://sixstringsupplies.co.uk/
    Our YouTube Channel for handy "How-To" Wiring Tutorials
    If you get a proper Log pot - as opposed to a cheap one that aren’t - then they’re fine. Turning down to about 8 brings it down to 500K and then it works just like a normal 500K pot.
    That’s about where you start to hear it, but only just. When I did some direct-switching testing with extra resistors, the minimum difference that could be definitely heard was about 25% below the base value, and 33% above. 600K is 50% above 400K so I think you’d hear that.
  • RolandRoland Frets: 8839
    It’s also worth thinking about increasing the value of the volume pot too.
    I wouldn’t call CTS or DiMarzio Pro Parts particularly cheap.
    Then I'm very surprised they don't work properly. The CTS one I put in my PRS was a very smooth, perfectly even taper all the way down, so every number setting was distinguishable from the one above or below - and that was a push-pull too! Often notorious for not being as good as a normal pot.
