Which Velcro
tone1tone1 Frets: 5316
Hi all!
Which brand of Velcro do you guys and gals use for your pedal boards?
Just moved over from the dark side of multi-effects unit to single pedals!
Cheers
Tone
  • steamabacussteamabacus Frets: 1291
    'Velcro' is a brand name, isn't it?
    I've not had any problems using the 'hook and loop fastener' from Maplins.
  • allicioallicio Frets: 221
    The duel lock stuff from strings direct. You only need a small amount in the corner of each pedal. Sticks like the proverbial!!
  • KerpunkKerpunk Frets: 75
    I prefer the tonal properties of cable ties.
  • KarlosKarlos Frets: 512
    Fabric shop near my house. If you use a PedalTrain the 50mm stuff is what you want. I got a roll of hook & loop with my PT-Pro as well.
    My mate used white velcro on his board thinking it would look cool and different and it just looks shit.
    (the artist formerly known as KarlosSantos)
  • bandmaster188bandmaster188 Frets: 401
    Yes this. Fixing pedals with cable ties creates a nylon based static charge that makes your pedals more powerful than you could possibly imagine. And hence better tone!
    The Swamp City Shakers
    Don't forget to really make sure the pedal is clean where you're going to stick the Velcro. You need that join between the sticky back of the Velcro and the pedal to be strong otherwise you'll be pulling it off every time you move a pedal about.
  • frankusfrankus Frets: 4719
    I buy 3M off the local market for £3 for 2 meters.
  • capo4thcapo4th Frets: 4437
    Dual Lock Velcro
