WITHDRAWN FS:FT Axe fx 2 with slight problem 900 !!! now 800 !!!!!
https://i334.photobucket.com/albums/m419/kotsadoros123/Mobile%20Uploads/974E5B2E-8D60-4393-B281-A17373F66EBD.png
Selling my axe fx 2 , had this for over 2 years now But i want to Give the kemper a go so here goes...
output 1 on the unbalanced side has significantly lower output than the balanced connection , everything else works as it should , ive been running it with xlr ‘s into my monitors and have honestly forgotten about it , if for some reason u want to use jack connections for the output you can use output 2 using an fx loop block ! As i said everything else including headphone out usb etc etc works as it should has been since I bought this .
I want 800for it !!! I think for what you get its a steal !
Any questions please ask
