Had all the parts, drilled the box a few weeks back, and finally found time to solder this up over the weekend. No gut shots, but it's basically a couple of switches (a 3DPDT and a 4DPDT) and LEDs (purple, no less).
I was after something to let me switch my Zoom G3 into and out of the loop on my EHX Superego, and while I was at it, I thought I'd add a bypass switch for the G3, too. Basically though, you could use it to switch your-pedal-of-choice to a different position in your chain...so, for instance, easy enough to do the shoegaze fuzz-after-reverb trick without having to hook it up there permanently. Best part? It works, and it's really useful. I might tart it up, but probably won't bother to be honest.
YouTube yak-about regarding all things alt/indie/post-punk/noise/etc >>>
HERE
