When using fuzz pedals (in particular, Big Muff's & Fuzz Faces), do you set the volume to be at unity gain/ slightly above or do you tend to set the volume on the pedal high to give your amp a proper kicking?
I've got a few different fuzzes and tend to run the volume around unity (Fuzz control maxed on a fuzz face and to taste on a Muff) but that often means running the volumes down quite low. Am I missing a trick?
I s'pose another option would be to run the volume high on the fuzz and turn down the amp.
How do you use yours?
