£360
Collection only near Cambridge. Not looking for any trades, thanks.
Body
* Body Material - Alder
* Body Finish - Gloss Polyester
* Body Shape - Telecaster®
Neck
* Neck Material - Maple
* Neck Finish - Satin Urethane Finish on Back
* Neck Shape - Modern "C"
* Scale Length - 25.5" (648 mm)
* Fingerboard Material - Pau Ferro
* Fingerboard Radius - 9.5” (241 mm)
* Number of Frets - 22
* Fret Size - Medium Jumbo
* Nut Material - Synthetic Bone
* Nut Width - 1.650" (42 mm)
* Position Inlays - White Dot
* Truss Rod - Standard
* Truss Rod Nut - 3/16" Hex Adjustment
Electronics
* Bridge Pickup - Player Series Alnico 2 Humbucking
* Neck Pickup - Player Series Alnico 2 Humbucking
* Controls -
Master Volume, Master Tone
* Switching - 3-Position Blade: Position 1. Bridge Pickup, Position 2. Bridge and Neck Pickups, Position 3. Neck Pickup
* Configuration - HH
* Special Electronics - Push-Pull Pot On Tone For Coil Split
Hardware
* Bridge - 6-Saddle String-Through-Body Tele® with Bent Steel Saddles
* Hardware Finish - Nickel/Chrome
* Tuning Machines - Standard Cast/Sealed
* Pickguard - 3-Ply Parchment
* Control Knobs - Knurled Flat-Top
* Switch Tip - Barrel Style
* Neck Plate - 4-Bolt with "F" Logo
