Is it a fact that...
pickup covers remove treble from the overall sound?
Stumbled upon the Rick Beato (whos that) rig rundown and his tech seemed to claim that it was a common fact that all covers remove high end? Is this true?
  • Sounds like BS, surely?!
  • p90foolp90fool Frets: 31969
    Some way more than others. Gibson humbucker covers are not too bad, but Epiphone covers used to be bloody awful though I don't know what the current crop are like.
    I usually get mine from @Alegree ; because his are sonically very transparent. I have Firebird, gold foil and 70s Fender pickups all hidden under his H/B covers in various guitars with practically no treble loss.
  • LewyLewy Frets: 4391
    edited February 2020
    Metal ones certainly can. Something to do with inductance or something clever.
  • CirrusCirrus Frets: 8502
    Yes, 100%. It's not even that subtle a difference.
    I had a set of SD A2P's in my Explorer 2008-2017, at which point I decided to install covers on them for cosmetic reasons. It absolutely changed the sound - dulls down the top end and changes the pick response. It was enough to make me not like the p'ups any more.
    I used good covers and installed them competently, so it's not that I borked the pickups. Covers just change the sound.
    To that end, I've just installed a Pearly Gates Trembucker in my Explorer because they're generally considered to be pretty bright up top, and I thought that a covered version of one of those would be just about right.
  • timmypixtimmypix Frets: 2476
    As far as I understand it a metal cover will absolutely interfere with the magnetic field which then results in treble loss. Different metal compositions do it to varying degrees - probably best asking @OilCityPickups or @Alegree for a proper explanation!
    Tim
  • OilCityPickupsOilCityPickups Frets: 11144
    edited February 2020 tFB Trader
    They act through eddy currents and effectively filter a little of the top end away ... absolutely correct.Nickel is the best metal for cover use, and the thinner the better ... brass is god awful. However the only cover that doesn't take a little off the top end is a plastic one. We have stopped making fully nickel covered HB sized P90s because the main reason the majority of HB P90s don't sound quite 'right' is that proper soapbars and dogears only have plastic covers! We now only do nickel 'rings' on our HB90s with open tops.
  • ICBMICBM Frets: 73088
    Yes they do, quite noticeably. There are two mechanisms - eddy currents in the metal which weaken the magnetic field above the pickup, and capacitance of the grounded cover to the coils which is like a small tone control turned down.
    Which is more important depends on the metal used for the cover, the amount of windings in the coils, and the dimensions of the coils and cover.
    It's not just humbuckers - you can substantially brighten a Tele neck pickup just by disconnecting the grounded tab (removing the capacitance) or removing the cover entirely.
    Metal-covered P90s on Epiphone Casinos sound duller than plastic-covered ones too.
  • First person I'm aware of swearing by this in an interview was Clapton in the 60's.
  • Someone should make a laminated pickup cover and stop those pesky eddy currents!
    Years ago you would sometimes feel ripped off when you found out your cheap humbuckers had chromed plastic covers, but I've spent the last couple of years trying to track some down with no success.
  • Used Monty's PAF's for about 3 years. Took off the bridge cover 'a la page', quickly soldered it back on. end off :)
  • KittyfriskKittyfrisk Frets: 19424
    This Eddy Currents chap sounds like a bloody nuisance.
  • This Eddy Currents chap sounds like a bloody nuisance.
    Indeed, I see no valid raisin’s for his actions. Suspect it’s just sour grapes.
  • I prefer uncovered... I do find covers muffle the sound a bit
    That has definitely been my experience...
    Isn't the metal pickup cover effect actually a treble reduction, rather than an overall muffling of the sound?
    Both - the capacitance takes off top-end only, but the eddy current effect softens the magnetic field overall and seems to reduce the bottom-end punch a bit.
  • Any thoughts on hollow/open/H-style humbucker covers?
  • So in conclusion, what you're saying is that not having a cover on a pick up not only looks way cooler (obviously) but sounds better too?!
    I always thought this was the case.  ;)
    All the right notes, not always in the right order!
    They have less of the dulling effect, for both reasons - there's less metal around the coils. I would guess the difference in magnetic effect is more important since it's over the top of the coils rather than on the sides.
