Electric shocks from laptop use and guitar...
I've recently set up a laptop in my room to record demos and such.
I've noticed, when I touch my laptop casing (when it's plugged in) and touch the strings of my guitar (Godin Session plugged into a Blackstar HT1 combo) with the back of my hand I get an electric shock. This only happens on my forearms or back of my hand, not when I'm fretting strings...
The guitar buzzes when not touching the strings normally so I'm assuming this means there's an issue with the grounding of the guitar?
What's strange is, with the guitar buzzing away, as soon as I touch the laptop the buzz gets louder.
Not sure what's occurring here, if it's the guitar, amp or laptop that has an issue.
Any help would be very much appreciated.
Cheers,
Shaun
  • maltingsaudiomaltingsaudio Frets: 3145
    edited March 2020
    Get it all checked by a proper electrician, or at least go to your local DIY shop and get a mains tester plug. Sounds like a faulty earth either on your amplifier check the mains lead or the house mains .
    https://www.screwfix.com/p/lap-ms6860d-socket-tester/91596?tc=UA7&ds_kid=92700022850517781&ds_rl=1241687&ds_rl=1245250&ds_rl=1244066&ds_rl=1249796&ds_rl=1245250&ds_rl=1249481&gclid=EAIaIQobChMIzOb9keKf6AIVj0TTCh3NwgDVEAQYAiABEgJnUPD_BwE&gclsrc=aw.ds
    www.maltingsaudio.co.uk
  • ChéChé Frets: 305
    Thanks so much! Is there a way of checking the earth of the amplifier with the mains lead?
  • Danny1969Danny1969 Frets: 10455
    Is it a laptop with conductive finish on the palm rest ? if so then the problem is caused by a difference in the laptops virtual ground and the real ground of the amp
    It's generally so slight though that's it well within limits and not a safety issue as long as you are using a real charger as not some cheap Chinese knockoff from Amazon or Ebay
  • ChéChé Frets: 305
    edited March 2020
    It's a new MacBook Pro with Apple branded charger. The whole finish besides the screen is a metallic silver, guessing it could be that?
    Yeah you get the same issue on Dell Latitudes and other laptops with conductive finish ... although annoying it's only normally felt from a really sensitive part on you body,..... I can feel it on my laptop if I touch the palm rest with the smooth underside of my wrist  but not with my hands
  • prowlaprowla Frets: 4946
    Its an erf loop thingy.
    If the amp and computer aren't plugged into the same mains socket then there will likely be a voltage differential between the computer case and the guitar earth.
  • ChéChé Frets: 305
    They are plugged into the same socket. I made sure of that to eliminate the obvious source of ground issues.
  • CeeJayCeeJay Frets: 455
    Differential between where?
  • springheadspringhead Frets: 1602
    Erf?  I don't think it's a loop, the laptop psu is likely class 2, i.e. unearthed.  Some of these switched mode supplies have EMI (Electro Magnetic Interference) suppressant capacitors between the low voltgae (output) and supply sides.  You can feel this if you are touching something that is actually earthed (your guitar strings) at the same time.  It's unnerving/annoying but unlikely to be dangerous (don't take my word for it if you're worried - get someone who understands switched mode psu's AND house wiring).  If possible you need to tie your laptop down to earth, maybe from a peripheral port if they have a connection to the laptop case.
  • KeefyKeefy Frets: 2322
    This sounds like the Switch Mode Power Supply on your laptop. The SMPS has a capacitor (sometimes called the Y capacitor) which goes between the mains input and the DC output. You can get up to about 90V from that, which can be pretty unpleasant, but the current available is insufficient to do actual harm. If you earth the DC the problem should disappear.
  • ChéChé Frets: 305
    edited March 2020
    It's my thinking that the laptop would be earthed through the power cable? I'll check when I get home tonight but granted Apple is a US product it wouldn't surprise me if it was a two pin cable with a plastic third prong.
    On the older chargers some were grounded and some weren't .... although they looked like a 2 pin fig 8 cable there was also a metal stud that the plus slid over and that was the ground. Oddly the supplied extension cable used to have the earth but they stopped shipping that. On those older chargers the protective film covering the charger could go over the metal stud effectively insulating it so it was important all that crap was peeled off properly.
    Yours will be a USB C charger though rather than a Magsafe which is a whole different ball game ... it’s a very complex system of voltage and current hand shaking ... it does have a ground but it’s not always connected to mains ground .  Often the only thing between the secondary side of the switch mode power supply and the primary is the Opto isolators So you’re not in any danger it’s just annoying sometimes
  • ICBMICBM Frets: 72634
    The laptop isn't earthed. This is quite normal with many laptops and their power supplies, including Apple ones.
  • guitartangoguitartango Frets: 1028
    Are you sure it is not static ?  I get this sometimes on our carpet at home.
    “Ken sent me.”
  • ChéChé Frets: 305
    edited March 2020
    Definitely not static. It doesn't happen when the laptop is unplugged. As long as it's not fatal I'll just keep my sleeves rolled down when working on the computer with the guitar on my lap.
