So - I am going to make use of this time to put new pups in one of them.
It's a T386 form Eastman - really like it.
Some people say - upgrade the electronics, the pots, the switches, the caps etc. CTS pots. Orange Drop caps. braided wire, switchcraft etc etc etc.
Here's my question. I used to be an electronics engineer many moons ago. I am really struggling to believe that any of that stuff makes any difference at all to what the thing sounds like. At the frequencies involved? If this was a high-frequency low voltage system then - yes - all of that is going to make some difference at some point - yip, you'd be over all of that. But at audio frequencies?
If you're making high-end audio equipment - you'll pay a fortune for customized, precision electronics - for the accuracy, the form factor, the aesthetic and the marketing bumpf that you can claim. But we are talking about Alpha pots (£0.50 at medium volume) or CTS pots (£1.05 at medium volume). What difference are you hearing? Don't get me wrong - I've done it myself - top end caps, poured over taper profiles.
Other than mechanical reliability is anybody genuinely 'hearing' any difference from slightly more expensive electronics? I am happy to be convinced - I'll go for it - but deep in the cockles of my rational side, it just doesn't seem plausible.
Anybody got a story or an argument in favour of upgrading the electronics, other than the pups?
Had to hold that there to go and clap the NHS workers. Thanks to any NHS guitar players folks!
"Thanks to any NHS guitar player folks!"
Thank you all
Although - I am wondering if the real beneficiaries are actually the future owners of these guitars - 2 or 3 guys down the line.
Military-grade components are usually burn-in aged (to weed out QA failures) and guaranteed to -50 to +125 degree operating temperatures. Pots will have a lifetime number of sweeps ratings. You'd probably have to spend all day for 10 years wiping them up and down their full range to wear them out if they are genuinely Mil-Std. Lol! I expect they are just less cost engineered than the really cheap stuff.
I jest - the reliability angle and having the best stuff is a good enough reason for sure.
Some ham-fisted guitar wearers seem to apply excessive force to their controls. I have seem lever switches leant on so hard that the wiper has been forced away from the contact leafs. On some pot chassis, is possible to press the shaft down against the base of the chassis, interrupting the contact between the wiper and track.
The orange drops fat legs make them easy to solder. Otherwise it's about the value, not the type. And they make next to no difference if the tone pot's up full.
Pots might be worth changing if the taper's not what you like or to alter the value for a slight tone change. If they work & do what you want I'd leave them.
Switches & jack sockets can be well worth changing for reliability esp the switch. But if you don't need it for gigging then it can wait till one fails.
Stuff can last a long time. e.g. I've a low-rent 50s and a MIJ 70s guitar where everything works fine, neither are top spec, must have relatively cheap lectrix. But if going deep fishing inside a semi-hollow it's worth thinking about re-doing the whole lot while you're in there.
