A list of technical guitar work
IanShawIanShaw Frets: 19
edited April 2020 in Guitar
After almost 30 years of playing guitar I am still trying to learn how to maintain and repair the instrument, so I thought it would be nice to write and share a list that contains the essential repairing jobs with the general guitar setup. I would appreciate adding other jobs to the list if I missed something.
  1. Complete rewiring including the soldering work.
  2. Testing electronic components.
  3. Grounding the guitar.
  4. Setting up the height of pickups (single coil and humbuckers).
  5. Setting up action (truss rod, bridge, and height of saddles).
  6. Setting up intonation.
  7. Setting up the tremolo (vintage, 2-point, and Floyd Rose).
  8. Re-fretting.
  9. Replacing the nut (graphite or roller nut).
  10. Replacing the neck.
  11. Upgrading the tuning keys.
  12. Cleaning and polishing fretboard.
  13. Fixing faulty strap screws.
What have I missed?
  • Neck relief? Although you’ve got truss rod in there... I guess with a bolt-on guitar though there’s also neck angle and shimming
  • FunkfingersFunkfingers Frets: 14727
    Finishing.
    Screening of cavities.
    Where appropriate, drilling holes for stud-mount bridges and tailpieces. Removing existing stud inserts.
    Fingerboard scalloping.
    Refitting the bent metal thing that secures Telecaster jack sockets.
    edited April 2020
    Fret shaping ; fret sprout correction  ; fingerboard rolling  - minor finish repairs or more depending on your ambition .. saddle replacements ; trem block upgrades .. scalloping ... pickup routing ..
    and deciding which butter your guitars will most play like after your skillful interventions ...
  • paulnb57paulnb57 Frets: 3091
  • IanShawIanShaw Frets: 19
    I don't eat butter.  :#
  • ColsCols Frets: 7265
    “Plays like low-fat soya-based spread” just doesn’t have the same ring to it.
  • digitalscreamdigitalscream Frets: 27071
    Errr...replacing pickups? Electronics upgrades in general?
    <space for hire>
    Custom refinishes à la (notorious eBay seller) TPP.
    Seven to six string conversions. (Another notorious eBaytor.)
    Here's an updated list based on your contributions:
    2. Routing for additional pickup.
    3. Testing, upgrading, and replacing electronic components (pickups, pots, capacitors, and switches).
    4. Grounding electronics and shielding the cavities (control and tremolo).
    5. Fixing scratchy knobs and switches.
    6. Setting up the height of pickups (single coil and humbuckers).
    7. Setting up action (truss rod, bridge, and height of saddles).
    8. Shimming for a forward/positive neck-angle (bolt on necks).
    9. Setting up intonation.
    10. Setting up the tremolo (vintage, 2-point, and Floyd Rose).
    11. Re-fretting and levelling frets.
    12. Smoothing sharp fret ends with dressing file.
    13. Finferboard scalloping.
    14. Fingerboard rolling.
    15. Replacing the nut (graphite or roller nut).
    16. Replacing the neck.
    17. Replacing, upgrading, and installing bridges and tremolo blocks.
    18. Replacing saddles.
    19. Upgrading the tuning keys.
    20. Fixing Jack sockets.
    21. Cleaning and polishing fretboard.
    22. Finishing and minor finish repairing.
    23. Fixing faulty strap screws.
    Thanks everybody!  =)
  • VoxmanVoxman Frets: 4788
    Neck skim
  • SunDevilSunDevil Frets: 511
    Repairing a guitar you set on fire?
    ...just me and Jimi then?
    This is a fantasy, unless Jimi would be alive again!
  • StuckfastStuckfast Frets: 2431
    I'd be a teeny bit nervous about using a tech who considered this essential. Or even desirable.
    Okay. How about scallop fingering?  B)
  • ZenOvertoneZenOvertone Frets: 234
    I'm also photographing the gear and noting serial numbers/mods too, just in case...quite a lot of new stuff not recorded yet
  • Relicing the neck/body/hardware.  ;) Soap/oil/wax treatment of unfinished necks. Adding/replacing inlays. Fretless conversion. (Ok, I went beyond the "essential repairing jobs with the general guitar setup", but will leave these for now...)
    Filling up pickup/bridge/battery/etc. cavities made during earlier upgrades.  :)
    Might as well list the crowning and polising of frets...
    I admit this is a bit special even though some legendary guitarists favour their fretboards to be scalloped. Steve Vai has the last four frets scalloped for easier playability on high registers. Back in the day, Rithie Blackmore took advantage of scalloped fretboard too.
  • KittyfriskKittyfrisk Frets: 19322
    OK, I'll expect the QI klaxon/alert here... but despite @IanShaw having a fantastic attitude toward helping people out, aren't we getting close to reinventing Dan Erlewine's ' How to Make Your Electric Guitar Play Great" ?
    I use those frets so infrequently that the dust makes me sneeze when I try.
    edited April 2020
    Update# 2:
    3. Filling unneeded spaces made during earlier upgrades.
    4. Testing, upgrading, and replacing electronic components (pickups, pots, capacitors, and switches).
    5. Grounding electronics and shielding the cavities (control and tremolo).
    6. Fixing scratchy knobs and switches.
    7. Setting up the height of pickups (single coil and humbuckers).
    8. Setting up action (truss rod, bridge, and height of saddles).
    9. Shimming for a forward/positive neck-angle (bolt on necks).
    10. Setting up intonation.
    11. Setting up the tremolo (vintage, 2-point, and Floyd Rose).
    12. Re-fretting.
    13. Levelling, crowning, and polishing frets.
    14. Smoothing sharp fret ends with dressing file.
    15. Fretboard scalloping.
    16. Fretboard rolling.
    17. Cleaning and polishing fretboard.
    18. Replacing the nut (graphite or roller nut).
    19. Replacing the neck.
    20. Replacing, upgrading, and installing bridges and tremolo blocks.
    21. Replacing saddles.
    22. Upgrading the tuning keys.
    23. Fixing Jack sockets.
    24. Finishing and minor finish repairing.
    25. Fixing faulty strap screws.
    26. Photographing earlier setup and gear status.
    27. Noting serial numbers and documenting modifications.
    Great list!...I may rearrange it.
