Tip (shamelessly stolen from a magazine interview with Andy Summers): Just because the box diagrams illustrate the fret/string positions that form a given chord shape, you are not compelled to hold all of them down simultaneously.
Summers often refers to note clusters. Break the chord down into simpler fragments.
In the context of a two guitar band, one guitar could take the lower three strings of a chord/scale box whilst the second guitar takes the upper three strings. The resultant cacophony could be Jazz. It could just as easily be High Life or Afrobeat.
Robben Ford states that this book is the basis of his jazz/blues based chord work
As @Funkfingers says above Break the chord down into simpler fragments
Again Robben Ford states this an Freddie Green played a career of such small chord segments - But this approach then allows you to play melodic inversions across the fingerboard and across all 6 strings
ie 6th fret - G string
5th fret - D String
use this for A7 - then move both fretted notes down 1 fret and you have D7 ie 5th fret G string and 4th fret D string - Move up 1 fret for E7 ie 7th fret G string and 6th fret D string - You may already know this - But a simple rhythmic 12 string approach and no movement required
play around with the following on EBG strings
Shape 1 - 5th/E 7th/B 6th/G then same shape moved down 2 frets 3rd/E 5th/B 4th/G
then shape 2 9th/E 10th/B 11th/G then same shape moved down 2 frets 7th/E 8th/B 9th/G
then shape 3 14th EBG then same shape moved down 2 frets 12th EBG
interlink and move around as required - all are a form of A dominant 6/7/9/13th etc and a host of melodic chordal progressions - Horn section style stabs etc
Easier if no other guitar player or piano player about so no 'dis-chords' against each other - So if you are on your own all such voicing's can work - If with other players than you'll have to be more selective
