Hi all!
So I've always been an acoustic finger picker. But I've wanted to branch out and finally get around the learning how to flat pick. Particularly for bluegrass, folk, blues and Country
The main trouble I'm having is support for my right hand when doing lead parts. Im going between resting it on the bridge to anchoring it with my pinky/ring finger but I'm not feeling particularly happy with either.
Because of the style I'm going for I'm trying to play closer to the bridge for the plucky twangy sound.
I want to be able to happily go between doing lead runs to strumming. The strumming I'm fine with - I let me arm float and I can still pick out the odd string for a hammer on or such.
I'm also unsure of the best way to hold the pick. I've been holding it at a slight angle so it's not hitting the strings perfectly flat and I find that is a lot better but I'd like to hear opinions.
Thanks guys!
Most people hold the pick the same way - imagine you're giving someone in front of you a straight-on thumbs up. Then place the pick on top of your curled up index finger, pointing 90 degrees out to the side, drop your thumb down on top of pick. Address the strings with a relaxed wrist and a slight downward angle.
