There are a huge number of different types starting really astonishingly cheap, if you look on Ebay - although you're best to spend a little more than the bare minimum, I would discount anything that doesn't have a recognised brand name unless you're truly looking to spend as little as possible.
This is about the cheapest I can see at the moment that's decent - these are a very old design now, and not exactly the most cutting-edge sound quality, but have been used by pro players and on well-known recordings...
https://www.ebay.co.uk/itm/Dean-Markley-Pickup-Pro-Mag-Acoustic-Steel-string-guitar-Good-condition/153912133540?hash=item23d5e0c7a4:g:mhYAAOSwS8heqGAh
The output volume isn't all that high but it should be enough to drive a loop pedal perfectly well without an additional preamp.
If it is... first, try setting it on the cleanest possible sound, with the bass about halfway or maybe slightly above, the mids very low, and the treble high. If the amp doesn't have effective enough EQ to do that, you could try an EQ pedal - or surprisingly, an acoustic simulator pedal such as the Boss AC-2. Although these are intended to make an electric guitar sound like an acoustic (which they don't, very much) they're actually very good for getting a more acoustic tone out of an electric guitar amp.
Have a look at your Taylor endpin - if it has an Allen key socket in the middle, it's bolted into a T-nut on the inside and the hole is 1/2" diameter, which is what you need for an endpin jack.
I actually have an old Fishman Rare Earth pickup which I'd been thinking about fitting to a cheap guitar, but I might be open to the idea of selling it if you're interested... probably a bit expensive for what you need though.
