Help mini humbuckers
GSPBASSESGSPBASSES Frets: 2351
in Made in the UK tFB Trader
I’ve never had to rout for mini humbuckers. I‘ve been looking to buy a routing jig I can only find them in America, does anyone know where I could buy some in the UK.
 Is there a standard routing for them  or several different sizes.
  Has anybody got the plans or a PDF file of them that I could buy from you.
  • FunkfingersFunkfingers Frets: 14457
    The routed cavity dimensions depend very much on the mounting method. Traditionally, Firebird pickups are suspended from a metal surround, LP Deluxe pickups are suspended through a modified P90 cover which is then connected to the floor of the cavity with a metal plate thing, Johnny Smith pickups are suspended via a bracket - either from the pickguard or around the end of the neck.
  • GSPBASSESGSPBASSES Frets: 2351
    edited May 2020 tFB Trader
    They going to be mounted on a pickup surround either plastic or metal don’t know what yet.
  • guitargeek62guitargeek62 Frets: 4140
    Scratch that - just measured a humbucker here and the baseplate is 3mm wider than a mini’s
  • guitarcookie1guitarcookie1 Frets: 464
    The Gibson mini-humbuckers I had were the same size as a soapbar P90, once they were in their pickup surrounds.
    The whole assembly then attached to a metal baseplate attached to the bottom of the pickup cavity.
    I do have a SG with mini-humbuckers incoming next week if you need any pictures/measurements.
