How would you get drums into a track
dariusdarius Frets: 689
edited May 2020 in Studio & Recording
Continuing to record acoustic and vocals with the young’ un, the next track could do with some simple drums. Maybe just a kick and shaker or side stick. I’ve got no midi keys or anything midi at all and I’m using Reaper so no virtual instruments readily available.
What’s the easiest way to get a simple drum track in?
 Was thinking of using GarageBand and exporting but feel it will quickly become a mess.
The billion drum plugins are mighty confusing.
  • octatonicoctatonic Frets: 34307
    A person playing a drum with some microphones in front of them.
  • dariusdarius Frets: 689
    Bit tricky at this particular moment in history
  • KeefyKeefy Frets: 2464
    I use this free plugin: https://www.powerdrumkit.com/download76187.php
    Lots of basic patterns, or use it as a sound module to play back MIDI drum tracks. You can easily open up drum patterns in the MIDI editor window e.g. to take out stuff you don't want.
    MIDI rabbit hole ahead!
  • mrkbmrkb Frets: 7399
    Record yourself scat singing the drum part and email it to me, I’ll chuck it into Superior drummer and find the nearest match and send you a wave file (or midi) of the part you can drop into reaper.
    Karma......
    Ebay mark7777_1
    If you have GarageBand I'm guessing you're on a Mac. Create a track, open up the plugins, and choose AUMIDISynth (Apple). You can then go into the MIDI editor and choose channel 10 to bring up percussion sounds. Drop in some bass drum and snare hits or whatever.
    Hey that works! Much thanks.
    Channel 10, of course! Like i knew...
    Colour me chuffed for you!
  • poopotpoopot Frets: 9100
    If your on Mac just use Apple drummer...
    crest anew drum track and hey presto drums!
    Approaching things from another angle, find or make things that you can hit or shake and stick a mic in front of them.
    I'm on a mac but Ive never heard of Apple drummer
    May well be doing that too / instead.
    Track menu up top... choose new track and then select “new drummer track”
    it will stick a virtual drummer in you song for you... you can configure it quite a lot... it’s the same as in logic but in logic you can control it further...
    https://soundcloud.com/user-617343615/genie-in-a-bottle-cousin-slippyfist
    That is using Apple drummer!
  • newi123newi123 Frets: 948
    As well as midi drums, don't forget audio loops. Lots of free sample loops including drums and percussion available. Look at the musicradar sample library to start. Easy to work with in reaper.
  • pintspillerpintspiller Frets: 1012
    This is what I use too. Use the supplied patterns or create your own.
    www.soundcloud.com/pintspiller will show you what I've done.
  • ewalewal Frets: 2815
    There's loads of free drum vsts which will work with Reaper. I have used TransistorDrums in past
    @poopot I think you’re talking about logic. I don’t have logic.
    @Keefy ive downloaded power drum will have a play tonight.
    Ta
    It’s in GarageBand as well... and that come bundled with your Mac ;)
    open a project, go to track, create new drummer track and hey presto drums...
