Totally unusable first 4 frets?
jacklawteyjacklawtey Frets: 294
So, this problem was only affecting the first and second frets on the B and G but after 6 months in its case, look how bad it is! Any idea what I can do to aid this? It's.. hilarious!
Here's a video of it in action (whey):
https://drive.google.com/open?id=1HAeQRrLq9qQtQ0_jEKbDi_mYGAcf5iOX
Thanks in advance for any pointers!
  • ICBMICBM Frets: 73027
    If you're lucky, the truss rod just needs loosening.
    If you're unlucky, the neck has a warp that the truss rod won't fix.
  • FelineGuitarsFelineGuitars Frets: 11734
    Guitar feels neglected after 6 months in it's case - needs some pampering
    Start with dinner and a movie , or a date night to show you care - avoid going straight to Netflix and chill
    More likely as ICBM said  truss rod needs loosening a touch
    Bronze strings looked a bit tarnished in the video .
    If the above works treat yourself to a fresh set?
  • jacklawteyjacklawtey Frets: 294
    If this guitar was a person, they should've left me long, long ago. The strings are a disgrace, I have some newies ready to go but I've been resigned to the fact the neck is warped. I'll try loosening the truss rod a little, see where we get to.
    So, the truss rod was just insanely tight. I added.. a lot.. of relief and we're back in action!
