Recording/Monitoring help
So today I plugged in my newly acquired Scarlett 2i2 3rd Gen to my  iMac.
Went to preferences and set the audio input and output as the 2i2.
Plugged in my Kemper (mono) - plugged the guitar into the Kemper - plugged in my monitor headphones into the Scarlett and did a test run. All good..
I opened up 2 new tracks, 1 for a WAV fle which I imported and the other for the Kemper.
I can hear the Kemper signal but not the backing track/music. I seem to get a clicking type noise if I isolate to just the backing track.
If I plug the headphones into the iMac and set the output as iMac, I can hear the backing music but no Kemper..
Am I doing something wrong or is it not possible this way with headphones and I need separate monitors to hear both?
I'm pretty new to recording setups, hence the post.
Any help would be greatly appreciated.
Darren
  • jacklawteyjacklawtey Frets: 303
    Did you change the input and output to your 2i2 inside of your DAW also? Also, do you have some kind of input monitoring selected in the 2i2 software?
  • Winny_PoohWinny_Pooh Frets: 8060
    Google "input monitoring" and your DAW name.
    How did you inport the WAV?
    Are you drag/dropping a 16bit 44.1khz file into a session that is setup at 24bit 48khz for example?
    Back to basics :
    Is the Kemper track's  "Solo" button armed? That will mute all else.
  • DarrenDarren Frets: 169
    Back to basics :
    Bingo!! I dragged and dropped the file from my desktop. Which I was doing previously with no joy.
    I went into the Focusrite control and changed the sample rate from 48khz to 44.1khz and it started working.
    Thank you very much indeed @jacklawtey and @Winny_Pooh problem solved ;)
