London Plane DC Build
SteveRobinsonSteveRobinson Frets: 7038
in Making & Modding tFB Trader
@Rab's London plane inspired me to build a guitar. So far I have the body blank cut and the top glued on.
Next job is to rout the binding channels but I'm waiting on binding so this afternoon, I thought what else I could do.
I decided to cut the jack hole which I did - ROOKIE MISTAKE. Now the binding cutter has nowhere to follow!
I'll have to cut what I can using the router then the couple of inches using a chisel.
Unless anyone has a better idea?
«1345
  • TTonyTTony Frets: 27608
    Use a hole cutter to cut a piece of scrap to fit in the jack socket hole ...
    Is that a mahogany body??
  • SteveRobinsonSteveRobinson Frets: 7038
    edited May 2020 tFB Trader
    Yes the body is mahogany about 38mm thick.
    I don't have a 7/8" plug cutter but I'll get some dowel and give it a go.
  • WezVWezV Frets: 16725
    I have done that before.   I just ignored that section when using the router and cut the last bit by hand with knives, chisels and files.  Not too difficult in that location as you can run a file round the edge easily to match the existing route
  • PeteCPeteC Frets: 409
    love the figuring in that top - this is going to be good .
    Looks beautiful, @SteveRobinson ;  I used the same wood on the back and sides of a couple of acoustics and they looked great.
    And yes - I've done that too ref the jack hole!  As @WezV did, I just avoided that area with the channel rout and finished off with chisels, etc..
  • JGTayJGTay Frets: 210
    That's some nice wood...
    Bung up the hole with a rag shoved in as tight as possible and put masking tape over the top to bring it level, it should allow you to get a close enough cut.
    @SteveRobinson can I ask how much the body blank weighs in comparison to Alder or Ash
    edited June 2020 tFB Trader
    @paulnb57 ;;The London plane is only a 6mm cap, the back is mahogany.
    I'm ready to rout the binding channels but I've decided to buy a new router so I'm holding off until it arrives.
    I inlaid acrylic MoP fretboard dots yesterday. I drilled while the board was still square and used a fence on my drill press so they are all in a nice straight line.
    I’ve got some London Plane from the forum supplier - ;) - it’s a weighty chunk of timber.
  • the_jaffathe_jaffa Frets: 1797
    Some of the figuring in that reminds me of the cover design of Unknown Pleasures by Joy Division.
    Right, binding channels cut, using @TTony's idea of filling the hole I'd prematurely made
    And binding fitted. This was a tricky job but I think it'll look okay when it's scraped back and cleaned up a bit
    Because the body has multiple binding I think the neck and headstock have to be bound too so that's my next job.
    The radius on the fretboard will make using a router impossible so I'll use a chisel.
    Nice work - and a lovely piece of timber!
  • JalapenoJalapeno Frets: 6393
    Great job !
    Feedback
  • WazmeisterWazmeister Frets: 9559
    Steve, that grain is gorgeous !
    Talented stuff. I so envy you guys who can build like this....
    It is thanks, I've got a matching veneer for the headstock face.
    I'm not sure about that, it's really been 90% thinking/anxiety!
    Nice work - this is looking lovely @SteveRobinson - that binding looks great with the plane top.
    jack hole/binding channel solution seems to have worked very well.
    What finish are you going to go for ?
    @PeteC ;The top will be natural, maybe with a slight amber tint.
    Back, sides and neck either transparent brown or amber.
    I'd like to get some ornate hardware/pickups though and am open to suggestions. I'm open to eitherr gold or dull nickel.
    It will have a tortoiseshell pickguard of some as yet undecided design though, thin enough that the wood shows though.
  • robertyroberty Frets: 10893
    I love that shape, the binding and the grain are class too. Looks great
  • MattNovakMattNovak Frets: 907
    Looks lovely so far - with a slight tint and a darker back that shape will have a slight Malcom Young Gretsch vibe to it.
    www.theflyingacesband.com
  • CorvusCorvus Frets: 2926
    Looking nice, like the binding. Might have to talk to Rabs about some plane too.
