My personal superswitch 2 pickup wiring
Winny_PoohWinny_Pooh Frets: 7898
edited June 2020 in Guitar
This is what I've personally found to work best for a med to hot bridge humbucker & lowish output neck (single or HB). Previously many of the inner coil/split combos I tried sounded too weak.
A - neck
B - neck + bridge (part split) in series
C - neck + bridge in parallel
D - bridge (part split)
E - bridge
In the diagram there is no connection for the neck inner coil wires on a 4 conductor humbucker so these would be taped off.
The bridge inner coil connections labelled green/white here can be reversed if things sound too thin or too fat in position D
Uses an Oak Grigsby/Fender super switch, not the Schaller (stock musicman type)
Heres a demo
Guitar has a firebird mini hum in the neck (Winterizer)
and a PAF (Fletcher w unorientated A5)
in the bridge
  • ICBMICBM Frets: 73061
    I’ve just done a similar one with a low-output Firebird-ish neck pickup (which sounded too thin in anything other than series) and a higher output bridge pickup.
    1 - neck
    2 - neck + parallel bridge
    3 - neck + series bridge
    4 - parallel bridge
    5 - series bridge
    I’m not normally a fan of humbuckers in parallel, but this particular one - an Oil City Brassknuckle - sounds good like that.
    This also has the advantage that all settings are very effectively hum-cancelling, more than if I’d combined both split pickups.
  • axisusaxisus Frets: 28354
    Sounds interesting but your diagram is scaring me. It's like the frankenstein of schematics.
  • SteveRobinsonSteveRobinson Frets: 7126
    @Winny_Pooh is Frankenstein, the schematic is his monster
  • RolandRoland Frets: 8849
    I’ll play. This is for single coiled Telecaster, where the bridge can be tapped:
    1. Bridge
    2. Tapped bridge
    3. Tapped bridge and neck in parallel
    4. Neck
    5. Neck and tapped bridge in series.
    This is a timely thread because Oil City are making me a pair of Brass Knuckles, and I’m wondering which settings to use. It will be a 5 way superswitch, so many combinations are possible. My first thought is:
    1. Bridge
    2. Tapped bridge
    3. Both tapped in parallel
    4. Tapped neck
    5. Neck
    but then I’m asking myself whether position 3 will use the same coils as 2 and 4.
  • Winny_PoohWinny_Pooh Frets: 7898
    Monster from the neck up, lover from the neck down :)
  • guitargeek62guitargeek62 Frets: 4250
    I like PRS’s approach to 5-way switching - particularly the second* variation they introduced (rotary pots from ~88-08). Now that they’ve moved to a blade switch on the Custom series they’ve gone for more “standard” options and (imo) lost some of the versatility - in particular the series singlecoil setting, which I use quite a lot.
    2nd gen rotary wiring (wired and later PCB variants):
    • Position 10: Humbucking treble pickup alone
    • Position 9: Outside coils of both pickups in parallel for what PRS calls a “deep and clear” sound
    • Position 8: Series singlecoils – PRS describes this as a “warm version of the classic in-between the bridge and middle pickups”
    • Position 7: Parallel single coils – Here PRS describes the sound as a “crisp version of the in-between the treble and middle pickups”
    • Position 6: Humbucking bass pickup alone
    3rd-gen blade switch wiring:
    - Position 1: Bridge humbucker
    - Position 2: Bridge humbucker with neck singlecoil, in parallel
    - Position 3: Bridge and neck humbuckers
    - Position 4: Neck singlecoil with bridge singlecoil, in parallel
    - Position 5: Neck humbucker
    Note: not the first config which had the horrid cocked-wah middle position.
