I've always loved hum-cancelling single coil pickups.
With Kinmans and DiMarzio areas each pickup on its own sounds beautiful. However the in-between positions lack the magic of genuine single coils.
Fitting the Ilitch was a bit of a faff but ultimately it was completely worth it...
I was originally under the mistaken impression that you require three pickups of identical wind and polarity.
There is actually however a diagram to use it with a middle pick up that is RW/RP - and it involves a conventional five way switch (not a super-switch).
The beauty is that in the in-between positions, the coil is out of circuit. The two pickups hum-cancel each other - and so you get the proper Stratocaster quack - that beautiful sound so reminiscent of Mark Knopfler.
In positions 1, 3 & 5 the coil becomes active and it cancels hum beautifully, whilst retaining that pristine single coil sound.
I wonder if the fact that the coil is out of circuit in the in-between positions might be a good thing - because the coil is supposed to match the impedance of the pickups (5.5kΩ - 6.5kΩ). That impedence of course halves in the in-between positions to 3kΩ approx, and the coil will not match it perfectly - but with an RW/RP middle pickup the coil is of course out of circuit).
there again the coil was fundamentally designed to work with three pick ups of identical wind and polarity. and Ilitch knows what he’s doing...
...now all that remains is to tidy up those two wires in the tremolo cavity.
I managed to acquire both an Ilitch backplate and an Ilitch pickguard. Fitted the backplate, and now the pickguard is due to walk the classifieds plank...
Very very pleased - Will post some recordings ASAP.
https://i.imgur.com/rbRCals.jpghttps://i.imgur.com/W8ar7lr.jpg
Still wouldn't have one personally!
They used to have an international dealer network, but that is no longer the case.
It's an interesting concept, certainly. I like the idea of wiring it with a RWRP middle pickup and switching it off in the 2 and 4 positions - although personally I'm not a fan of very 'quacky' Strat sounds - but from a look at the schematics they wire the tone controls to the neck and bridge pickups, not the middle - which I hate. That may be because the tone controls are not fully independent if they share the same cap, but you could do it with two separate ones.
Idle curiosity, really
but since you are using only one side of the switch for the pickup signal wires and the output to the tone controls, two pickups cannot share the same tone control...!
Having played in a couple of such venues, that is exactly why I won't have any gigging guitar or bass without at least one hum-cancelling setting on it, and preferably on all settings.
Anyone who hasn't, and who thinks single-coil noise is just a minor inconvenience that you can't hear when you're actually playing, is probably in for an unwelcome wake-up at some point.
I know single-coils can sound great... but for me it's not a worthwhile trade-off for live playing. I now don't own a single instrument without hum-cancelling pickups, even though some of them look as if they have single coils.
https://youtu.be/3GYyHOkqUiY
The buzz is sufficiently mild, that it’s not worth the effort to fit the pickguard-based system that I also have (which is now in the classifieds here).
What this does illustrate perfectly is the difference between noise that can be blocked with shielding and noise which needs a hum-cancelling coil to remove - even though with a lot of modern noise sources it's not as clear cut as 'buzz' and 'hum' used to be.
I had customers ask for their guitars to be shielded to stop them "buzzing", and then complain that the guitar still "buzzed" afterwards, which is a bit awkward when you're charging money for it - and have to explain that you did indeed do the job properly, but that they didn't understand that it wouldn't do what they expected - which was not their fault.
That's why I've always tried to be careful to use the terms hum and buzz separately - the problem now is that switch-mode power supply noise, which is common now but wasn't thirty years ago, sounds like 'buzz', when it is in fact 'hum', so it's even harder to explain the difference...
