If you already had something to cover the main types of basses, I.e. A precision, jazz, stingray, active soap bars, one for flatwounds etc. and you also had an additional bass, do you know of any unusual pickups that would give something different to the others?
Let's say it's routed for a J but can be routed further if necessary. Anyone know of any unusual bass pickups that sound good and different to the standards?
Couple of thoughts I've had have been a bridge pickup that Oil City makes that is meant to sound like a Ric. Maybe the old single coil P pickup if that would work in the neck spot of a jazz. Maybe even a guitar pickup if any of those would sound good?
Appreciate any suggestions.
@JezWynd seems very keen on ye olde Höfner pickups. Some of this might be to do with their positions along the string.
Presumably, this refers to the four pole screw bass version?
I have STILL yet to try this pickup. I do, however, have first dibs on one if its original purchaser decides not to keep it.
One note of caution. One of my favourite comments about RIC 4001/4003 bass guitars is that they still sound like a RIC when they are not amplified.
The original single coil P Bass pickup is of relatively low output. Higher output and noise-cancelling variants of it exist - at a price.
Oil City built an SCPB-sized Overkill pickup for Bridgehouse. Descriptions of the sound may appear in his thread about the project bass.
That’s probably enough waffle for now.
One thought I had when I saw this pickup on the Oil City website is that there's only a bridge position - do a lot of Ric players play with just the bridge pickup on or is that the "classic" Ric sound, bridge only?
The point about it still sounding like a Ric unplugged will apply to most of the options I imagine, i.e. putting another bass's pickup in a J won't transform it completely in to that other bass but I'm fine with that, not trying to get a Ric on the cheap, just ideas to create something with a different application than a Jazz.
That's what kind of confused me about there only being a bridge for the Overkill, is it meant to sound like a Ric when combined with a normal J neck pickup or when it's soloed or would there have to be a neck pickup that's like the Ric's neck pickup to properly get the sound?
While I could believe you could get a fairly Rick-like ‘bridge’ sound from a Jazz, the Rick neck sound is very different - you could possibly get close with a separate tone control, but you would need a stack-knob type wiring scheme to stop it affecting the bridge pickup.
The relative positioning of the pickups on a Jazz and Ric help.The Jazz bridge pickup position is closer to the bridge than the Ric, which I think helps get the clang element that one would want. We will attempt a Ric neck pickup at some point, but as the Jazz neck position is closer to the Ric bridge position than the Jazz neck, I am not exactly sure what that will sound like in a Jazz. I have a dream of a custom P bass body with the pickups routes in the Ric position - might look weird, but I suspect we can get it to sound like the big R :-)
Interestingly, when I'd broken my arm a couple of years ago and for a while couldn't reach the far end of my Rick properly, a friend lent me a Mustang Bass, which was pretty close to the Rick bridge pickup (which I use most) - I can understand why quite a few bassists in the early 70s used both. The Mustang doesn't have the low-end punch of a P-bass so it sounds more like the 4001/treble-cap Rick.
It's also surprising how much difference there is between the "1/2 inch" and "1 inch" positions for the Rick neck pickup - my first proper Rick was a 4003, and I never felt the neck pickup had that McCartney late-Beatles-era deep thud. When I got my 4001 which at the time had a Bartolini, it immediately had that sound. I put a Rick HB1 in, then finally a 'Toasterbucker', and they all sound basically the same - it's the position that matters.
Hope there are some demos on the web, I haven't actually looked but will after work today.
