Instagram
Hmmm... would be good to know which pieces are missing.
A couple of scratchplate screws probably won't make much difference... but if it's missing it's neck and pickups that would be a different story! :-)
Originality makes a big difference to values - some pictures would really help.
Happy to help out further if needed.
Thanks.
The pictures don’t show the serial number plate - my gut feeling is this could be one of the guitars sold off at the death of Hayman as unfinished - all of them I’ve seen are missing the control cavity plates.
Without having it in my hands to check the neck and it being left unstrung are concerns - the truss rod can seize - and I’d like to check over the neck carefully before giving a proper valuation.
It’s not worth a fortune tbh, even though it’s probably a lovely guitar. This Shergold/Hayman collector would put it in the £350-500 ballpark, and that is tentative and dependant on a thorough check.
I hope that helps.
The pickguard does look black, which as you stated isn't original by the other photos I have seen.
Below is the pic of the serial number on the back plate.
Thanks for all the help.
https://linksharing.samsungcloud.com/jeqdsTHEV8Fg
Ah, so it does have a serial... therefore its a production guitar that's been modded.
Depending on where you are in the country (I'm Northants), I'd be happy to give it a thorough look over if that helps.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
True...
