I bought this cheap Squier affinity telecaster of a bloke that I saw advertised locally on facebook marketplace. It only cost me 70 quid and have to admit is was pretty much mint. I did notice that the nut wasn't that well cut which meant it needed changing to bring the high E string further inboard as it was too close to the fret ends. The intention was to use it as a test bed for pickups, pots, different wiring configs before I go and butcher one of my US teles. I knew the action was a bit high but I can't straighten the neck on the truss rod because it runs to the end of it's adjustment. What can I do about it. Washer?
Ian
Lowering my
expectations has succeeded beyond my wildest dreams.
You use shims to control neck angle on a bolt on neck
Instagram
The truss rod adjusts the *relief*, or curvature of the neck, not its angle.
Lowering the bridge saddles when the action is too high, when the real cause is too much relief, will make the guitar buzz and choke out at the top of the neck while still being hard to play in the middle. This is how almost all guitars which arrive at the shop for a set-up are like, precisely because the owner has lowered the saddles to try to make the guitar easier to play, when the real problem is the relief.
The correct solution is to straighten the neck and often to *raise* the bridge/saddles.
Yes, if the adjuster has run out of thread rather than just being too tight to adjust further.
Ian
If you fret 1st and 16th fret, is the gap similar? ifs fine knowing if the board is flat, but it doesn't tell you if the tops of the fret are. if its ever been leveled without the neck being perfectly straight first, the gaps could be different
the gap isn't out the realms of playable as it is, certainly not for a heavier strummer. the guitar should be able to pull off a playable action, but definitely not a low one. Worse case is a £70 slide guitar
Instagram
Ian
The second approach came from helping a mate keeping his teaching business running. Hundreds of cheap guitars that often needed to be made playable as cheaply and quickly as possible. If I was spending more than 15 minutes on any guitar, it was too long. In this situation I would make do. In most cases, i was able to achieve something nicely playable in that time, but a perfect set up it was not.
If this was a thread about a high priced guitar my advice would be different, but ultimately you are free to decide the level of investment you make in it. I have certainly invested in many a cheap guitar myself.
Try the washer
Instagram
Ian
