£450 collection from near to Dorking. Happy to send at buyers cost and risk.
The Bose S1 is a high-quality, ultra-compact PA System that projects the much-loved Bose sound from a much smaller and more affordable package. With a unique acoustic design and best-in-class sound quality, the S1 is perfect for small gigs. When you need a quick and compact setup that sounds fantastic, the Bose S1 will provide!
If you've been looking at acoustic guitar amps, or other small mono PA setups, the S1 could be a more compact, versatile and better-sounding alternative! The S1 Pro Compact comes with a rechargeable battery that has up to 11 hours of playing time. That means that you can get out and go busking without worrying about where your power is going to come from.
Channel 3 is an aux-in that allows you to connect your smartphone or an external device, to play backing tracks or trigger samples during your set. However, the Bose S1 also features built-in Bluetooth so that you can connect your mobile device or tablet wirelessly, with a secure and high-quality audio connection.
Compact & Versatile Cabinet Design
As with all Bose PA Systems, the S1 has been designed for the ultimate in acoustic performance. From it's articulated array of speakers that provide consistent coverage in a room, to its cabinet acoustics and low crossover that's optimised for vocal clarity, this is an incredibly potent speaker.
The S1 Cabinet is also designed to be positioned in a few different configurations, so that you can get the best coverage for different applications. In addition to the regular stand-mounted position, the S1 can also be tilted back for stage placement, or put on its side as a floor monitor. You can even combine 2 S1's to create a stereo setup!
Features
Lightweight & Portable: Weighing about 15 lbs (6.8 kg).
Versatility meets Simplicity: The S1 Pro comes with a full-featured, 3-channel mixer with reverb and Bluetooth® streaming. Sound great quickly with ToneMatch® processing.
Adaptable: Multiple positions give you the best coverage option for your application, while Auto EQ maintains optimum sound in any orientation.
Impressive size-to-performance ratio: The S1 Pro delivers high-output in a small package, ready to serve as your ultimate all-in-one PA, floor monitor, practice amplifier or primary music system.
High-output sound from a small, convenient system that is ready to perform whenever and wherever you are.
Lightweight, ultra-portable enclosure is designed to transport effortlessly using the convenient carry-handle.
Onboard 3-channel mixer offers independent ToneMatch®, reverb, and EQ controls on two channels, with a dedicated channel for either wired (3.5 mm) or wireless music sources.
Wireless Bluetooth® streaming from your mobile device, with one-touch pairing.
Speaker stand compatible with standard 35 mm pole mounts.
Free rechargeable lithium-ion battery allows you to perform anywhere for hours.
Mixer with built in ToneMatch Engine.
The S1 Pro Rechargeable Battery
Power-up and play your Bose® S1 Pro system for up to 11 hours using the add-on rechargeable S1 Battery Pack. This lithium-ion battery installs easily into the dedicated compartment on your S1 Pro for secure and reliable use. Use the Quick Charge feature to recharge your S1 Battery Pack in a hurry.
Up to 11 hours of charge time when used at high-output levels for performance use you can count on
Lithium-ion battery technology provides high energy density and full-output use of your S1 Pro system without compromising volume level
Dual charge modes allow the S1 Battery Pack to be trickle-charged while the S1 Pro system is in use with AC power, or when not being used for play, the switchable Quick Charge mode can be used for rapid charging
Permanently install the battery inside the S1 Pro system for safe and easy charging
Specifications
Low-Frequency Driver: 6'' Woofer
Frequency Response: 70Hz - 16kHz
Coverage: 100° x 40°
Sound Pressure Level: 103dB, Maximum (109dB Peak)
Input Channels: 3
Channel 1: Microphone/Instrument
Channel 2: Microphone/Instrument
Channel 3: Aux/Bluetooth
Input Connectors:
2 x XLR/TRS Combo
1 x 3.5mm (1/8'') Jack
Output Connector:
1 x 1/4'' Jack (Line)
EQ: 2-Band
Bass
Treble
Controls:
Reverb (Channel 1&2)
Level (Per Channel)
Other:
Bluetooth Wireless Range: 9m / 30ft
ToneMatch: Off/Instrument/Microphone (Channel 1&2)
Pole Mount: 35mm Socket
Power Supply: 100V - 240V or Lithium-Ion Battery
Dimensions: 330mm x 241mm x 286mm / 13'' x 9.5'' x 11.2'' (H x W x D)
Type: Lithium-Ion
Playback Time : Up to 6 Hours
Charge Time: 3 Hours (Quick Charge) - 5 Hours (Trickle)
