Torpedo Wall of Sound
Forgive the n00b questions, but I can just use this with things like the Neural DSP plugins, Helix VST, Mercuriall Spark etc. correct? Just have to turn off the cabinet section on the 'guitar' plugins?
And can I load any IR into it, or does it have to be their own? I own quite a lot of the Celestion IRs, but saw Torpedo sell their own Celestion packs.
  • adaminoadamino Frets: 125
    Hi yes you can disable the VST cabinet selection and run WOS as a second plug in after the Amp Sim.You can also Load External IRS too ,however,WAS cab sims available to buy are excellent too and give you a wide range of options.
    I use the TWOS and it's great. Makes my old POD HD rack unit sound really good.
  • FarleyUKFarleyUK Frets: 2386
    Brilliant, thanks both!
