Internal trim pot orientation question
FuengiFuengi Frets: 2850
Once bitten....
Can anyone advice me on which way to put this internal trim pot in to the PCB?
The instructions show a bias pot but this is in the kit, I'm assuming it goes in the three offset holes with Bias outlined below the external pot holes which will be unused? I don't know which way the pot should go though.
  • RolandRoland Frets: 8701
    Aren’t the three pins already bent so as to align with the three holes in the circuit board?
  • FuengiFuengi Frets: 2850
    Yes. I bent them to see if it would fit. ;)
  • Paul_CPaul_C Frets: 7778
    Well the pins are numbered, does the board or circuit diagram not show which goes where ?
  • ICBMICBM Frets: 72307
    Yes, like that :).
    I've looked on the Fuzzdog site, and by the looks of things Pin 1 is on the left.
    The only thing to bear in mind is that the trimmer you have is much harder to know where it's set, as it'll be multiple turns from one extreme to the other. (you can hear it click when it reaches either end)
    ICBM said:
    Yes, like that :).
    Thanks again chaps.
    It doesn’t matter which end is which, it’s a linear potentiometer. Fit it how it fits, that’s all.
    Another one I can't get working!
    Been ultra carful to follow everything to the letter and checked the switching etc. I checked the voltages across the IC DIL socket as suggested but I don't know how to work out what they should be.
    The bias trimpot seems to turn forever befor reaching a click. I got it to click one direction but must have wound it dozens of time the other way without any click.
    I've got no idea how to test to see what wrong with it!
  • Danny1969Danny1969 Frets: 10404
    What kit is it ? if there's a circuit diagram I could tell you what voltages will be where
    edited September 2020
    The schematic is in the instructions on this page Danny.
    https://shop.pedalparts.co.uk/P45_Phaser/p847124_7971603.aspx
    Ok, the opamps are TLO72 ... these are general use dual opamps so each package contains 2 opamps .
    Pin 8 should be 9V when referenced to ground
    pin 4 should be ground ... so measure between 8 and 4 will give 9V
    Check that on both opamps
    Signal comes in on non inverting input pin 3  .... that will be biased at half the 9v rail roughly so around 4.5V ... so read that between pin 3 and 4 of the first opamp. As a general rule this applies to any opamp used in that config with a single ended supply like a guitar pedal has to use
    Check the FET's are the right way round .. this is easy mistake to make
    Check any diode is right way round too
    Then see what you have
    Thanks for this Danny. I've checked the voltage across opamp 1 and have the following readings;
    Pin 1 - 4.4v
    Pin 2 - 4.4v
    Pin 3 - 3v
    Pin 4 - 0v
    Pin 5 - 4.3v
    Pin 6 - 4.4v
    Pin 7 - 4.3v
    Pin 8 - 9v
    Checked the diodes and the FETs and they look right to me. I think I've even got the electrolytic capacitors in the right way this time!
    Ok if opamps good and FET's defo right way round it's likely to be a wiring mistake ... here a signal probe is a handy device but prodding pins with a small metal conductor will suffice .... if the pedal is connected to an amp then you can work backwards from the output ... if good then there will be a buzz when you touch the contact, bit like when you touch the lead before you plug into unto your guitar.
    Prod pin 1 of IC2 ... with the pedal turned on, do you hear a buzz ? if so go to pin 1 of IC1 and probe that ... if you have lost it then it's possibly  a switch problem, try jumping the switch
    Take heart that everyone makes mistakes building these things, I've built circuits I've designed myself and still f#cked up on something silly :)
    Can't work it out. The only thing I get is a short between CI and Ground when the switch is engaged, but that's normal i think?
    So Pin 2 and Pin 3 of each IC do give a buzz when I prod them. Does that help?
    Shouldn't be. CI is the circuit input so it should be an open circuit (assuming you haven't got a guitar plugged in and turned down!) when the switch is set to on and grounded when set to bypass. If you've used the switch PCB you can't have wired the switch backwards though...
    I have used the switch PCB, yes. Those switches can go either way I believe?
    If the holes in the PCB are round not oval, yes. You need to be careful to fit them so the flat terminals are lined up across the width of the pedal not along its length...
    Like this:
    Like this:
    Fuzzdog ones only go horizontally. I can't see what I've got wrong with the wiring?
    Nothing I can see that's obvious - unless the spring terminal on the input jack is touching the casing?
    (Just as an aside, why do these kits never give you shakeproof washers for the jacks? Or most boutique pedal makers fit them...)
