I've removed some blinds from the inside of my conservatory which the previous owner installed. The brackets were drilled and screwed into UPVC and has left holes that I want to repair. I don't expect an invisible repair, because I won't be sanding down the UPVC (unless someone can explain why I should) or repainting. I'd like to fill the holes in a similar colour (standard conservatory white) and make them less noticeable. The UPVC pieces are hollow inside, so they're proper holes rather than a crater (IYSWIM).
Any suggestions? I'd just replace the parts if it was straightforward, but it isn't.
Nil Satis Nisi Optimum
https://www.ebay.co.uk/itm/221875515304
https://www.ebay.co.uk/itm/Weiss-Cosmofen-RM-PVC-UPVC-Window-Door-Frame-Dent-Crack-Filler-Repair-Mass-Kit/123790810669?epid=23007811948&hash=item1cd281de2d:g:6YkAAOSwUlFcNIVm
https://www.amazon.co.uk/White-Plastic-Epoxy-Repair-Putty/dp/B07L45ZZF8/ref=pd_bxgy_img_2/261-5172883-1241815?_encoding=UTF8&pd_rd_i=B07L45ZZF8&pd_rd_r=13c1f753-46ac-49d7-a74d-4baa845a1d8c&pd_rd_w=8lMHz&pd_rd_wg=SEBic&pf_rd_p=dcf35746-0212-418b-a148-30395d107b2d&pf_rd_r=C63EYNNPS55B5WABSVZ0&psc=1&refRID=C63EYNNPS55B5WABSVZ0
Something like this should sort you out https://www.toolstation.com/plastic-dome-screw-cover/p85514
