Pickups, they seem like a never ending roundabout of either disappointment or mild dissatisfaction for me. I don't think I'm ever that satisfied with most of the ones I've had. I'm the most satisfied I've been in ages right now in that I rather like the Kinman noiseless neck pickup in my Tele, although I don't like the matching bridge pickup or the middle switch position. I also rather like the Suhr V70s in my strat neck and middle, but the bridge is just too underpowered for my liking. I've tried a fair amount of other pickups in the bridge position but nothing satisfies me thus far. I don't think I've ever had any guitar where I thought that the pickups were 100% what I'm looking for. I'm a fussy bugger but swapping is an expensive hobby.
Whatever one has, it is possible to imagine that there might be something better.
I am also a fussy bugger but I adapt the way I play to what each instrument makes possible.
Ignore it and go and work on your playing.
Football is rubbish.
Keep em stock!
It’s weird because if you look at my amp and pedals I’m a boutique makers dream, but I’ve tried all the boutique pickup makers over time and none lasted more than some of the more down to earth Seymour Duncan’s and the like.
Or do you really know what you want if not you may be making the wrong choices.
I see this all the time, across different instruments and it seems to only really happen online.
Not a single musician that I know who isn't on the forums seems to be swapping pickups, or pedals or drum heads or clarinet reeds.
Most players seem to keep the same gear year in and year out and it seems to work.
I've gone through periods where I swapped out pickups but often you aren't making it better, you are just making it different.
However, I'm not on a merry go round and when something easily does what I want it stays, usually bridge pickups:
ES330 - creamery A2, 9 years old.
Prs S2 - Mojo A5, 3 years old
Musicman - Fletcher unor A5, 4 yrs old
12 string tele - Fralin blues, 14 yrs old
Neck pickups do get more regular switching as clean tones can get very particular for each guitar.
No need, my standard stuff is perfectly adequate.
In the end I just accepted that I couldn't make them sound as good other people do and moved onto something else which, for now, works better for me. I guess the telecaster is my favourite guitar that cannot get on with.
@octatonic I love that expression "majoring in minor"
Generally I think Gibson pickups are pretty good but I do think it's worth upgrading pickups in a cheaper guitar, the stock cheapo ones are often muddy and dull sounding. Also the stock pickups might not be quite right for what you're playing - probably wouldn't want to play metal with some low output A2 PAFs as it'll sound a bit soft. They do make a difference but I think once you get to a certain level you hit diminishing returns pretty quickly. I don't think I'd buy Bare Knuckles new any more, but Oil City and Alegree are well priced and the same level of quality.
However I must say that the Mojo esquire in my Tele is fantastic, so you can find pickups to suit.
Oh and I agree, I never found a Strat bridge that I liked. Maybe I should have got a pedal board to sort that one out
I put a TV Jones classic + in a Gretsch jet to replace the fender ceramic Filter’tron and it perked that guitar up and added a bit of beef while enhancing the Gretschiness.
I have a plan to change a pickup from a P90 to a T-Armond on another guitar to bring out some extra treble.
But I only have 3 guitars and generally only use bridge pickups for the most part so some tweaking is fine IMO, and I don’t really care about the other positions.
- on a cheap (say sub-£500) guitar, as that's where you'll see a big difference between handwound stuff and the cheap own-brand pickups these tend to use.
- you want to radically alter the output/response (turn an LP into a metal machine, a modern strat into a vintage style, etc)
The rest is really diminishing returns. Yes it might sound a bit clearer / more defined, etc but it's marginal gains at best.
I'm saying that being fully guilty of changing pickups in pretty ever long-termer I've had, regardless of quality... But usually it's a one-off, I'll get a set of nice handwounds and stick to it. Took me a couple tries on the bridge of my SG though.
And it's also because I do the overwhelming majority of my playing alone, through headphones where it's easier to notice. I very much doubt I would bother if playing with a band, as long as the pickups are good quality and do broadly what you want them to do money would be better spent on a different pedal I reckon. Don't think any audience will gush over my unpotted, handwound pickup with carefully selected A2 magnet...
