Save your project.
Save it again using "Save As" and give it the same name appended with "test_keychange" or something similar and make the changes on that version and let us know if it screws things up.
You can go back to your original if it does.
This is how you learn things- by experimenting with things you need to figure out.
You might need to look at the Transposition Track. I’ve only tried changing the Tempo of a project after recording some tracks, and GB seems to ‘helpfully’ adjust everything as a result. There’s a checkbox on tracks for Follow Pitch and Tempo, but unchecking that seems to have no effect.
Please post if you find the answer!
If the auto-Tune plug-in permits, ask it to operate in C Dorian mode. All the right notes, necessarily in the right order. Just beginning on a different degree of the scale.
