Just in case it matters for anyone who doesn't know why, if you put a Bigsby on any guitar with a piezo bridge pickup, it will make horrendous amplified noises if you actually move the Bigsby arm, as the strings grind and squeak over the bridge saddle - and that's even ignoring the massive tuning issues it's likely to cause.
A Bigsby, especially one with the front tension bar, *must* be used with a rocker or roller bridge (yes I did mean to say that ), or at worst with smoothly polished hard metal saddles.
Also it is described as a 1990 Gibson Chet Atkins CE Classical, but it looks to be strung with non nylon D'Addario's.
But it sounds OK here:
