https://uk.rs-online.com/web/p/rectifier-diodes-schottky-diodes/6298679/
Best place to get another PT ?
You can buzz this out to check if there is continuity.
You can bypass the thermal fuse, but of course I am not recommending you do that....
Getting replacement parts from Fender has been a pain recently, but if you can't get on from them Hammond make a good repro unit, part no 290UEX, which you can get from Tube Town, or Mouser.
Also, if you haven't done it already then do the 230/240V swap so the amp runs cooler as well.
But I could be being a bit dense, I probably repair less than 5 valve amps a year so appreciate your help @jpfamps and @ICBM
I don't regard this as dangerous since very few amps actually have them anyway, and transformer fires are very rare - at least as long as you have the correct fuse in the amp.
And if not already done, swap the black and the white/black wires so black is on P4 and white/black is on P10, this sets the amp to 240V not 230V which reduces the stress on everything - including the risk of board arcs and fires.
Thanks for your help guys, much appreciated
