I need a pot nut that’s an odd size.
I have a Tonefreak Severe pedal that I recently had to take apart to replace a broken switch and managed to lose one of the pot nuts (clever, I know!!).
I have a little tin of assorted nuts of this type and none seem to fit. I’ve tried emailing Tonefreak and got no response.
The pots seem pretty specific and have locating tags to keep them from turning... I’m reticent to replace the whole pot if I can avoid it.
It’s a mini pot and the threaded collar around the shaft is very thin compared to most others. I don’t have a set of callipers to measure exactly.
Any ideas anyone???
If you could measure the thread diameter, and preferably post a picture of one of the other ones (or measure its dimensions and say what type of metal it looks like), I should be able to match it for you.
The only danger is knocking the box of nut/washers/screws/etc. onto the floor.
I bought a box of old tuner bits for £35 when I started out, and I'm sure it's earned me more than that since, in cash and goodwill.
