Instagram
What is the diameter of the pre-drilled ‘head post hole? How far is it in from the upper edge of the headstock? Is your project instrument left- or right-handed?
here’s the fender version:
True and this one is going to look special too with the paint, I can't imagine my dremel work would improve that
Expect a for sale thread imminently!
It's a right handed P Bass, no ruler or tape measure to hand at the mo. The tuner holes from the face are 17mm, can't remember the diameter from underneath
It should be possible to dismantle both sets of Schallers to construct a working hybrid.
Approx 17mm diameter on top and 14mm from the back...
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Guess what? I have a box of Schaller BM ‘heads that I would have happily traded for the Kluson-alikes. Feck! Arse! Knickers!
@GSPBASSES - Not to worry, the replacements are on the way.
That is a shame @Funkfingers - but if you need a new and unused set of the bigger Schallers, you know where I am
