That is just what OC-2 models do. Warbly, glitchy and apparently that's why they have a character!
I have no idea why the OC-2 is loved so much.
The "Oct 2" mode is a copy of the old OC-2 pedal, hence I called it that.
You can help it track better by putting a compressor in front of it, but many OC-2 lovers claim the glitchy stuff is part of the charm.
Like a lot of technically bad sounds it can be useful when you get familiar with them - you can usually get it to do it, or not, depending on how you pick and where on the neck you're playing.
It’s worth remembering that feedback and even distortion were once considered unmusical problems with amplification, until players learned to use them creatively. The OC-2 is just a bit more unpredictable.
