I just don't see the point in having two units when you could combine into one. I guess there's a slight argument about reliability if one breaks but convenience would trump that for me.
https://www.thefretboard.co.uk/discussion/190274/hx-effects-into-stomp-and-amp-patches#latest
Also, the next firmware update is rumoured to increase the number of blocks you can have in the Stomp...
Main advantage over the LT is that you get the scrobble strips on the HX effects.
Plus I can use 2 footswitches on the stomp for amps and one for turning reverb on or off.
Other advantages are you have a backup solution for the HX if it fails, and size wise it's still smaller than the LT.
I am tempted to try a preamp n the loop of the HX and use IR'ss from the HX. That might work well.
I’m not, it’s here early..
Have a great Sunday playing! How are you getting along with it?
I’ve found the Austin Clean & Austin Lead to be my favourites of the presets.
