Tele & Strat Parts - TV Jones, Gotoh, Schaller
CasperCasterCasperCaster Frets: 769
edited October 2020 in Parts £
I have a number of Tele and Start parts for sale. All items are priced to include postage to your UK mainland home address, and assume payment by PayPal Gift / Friends & Family. Sorry, no trades at this time.
Just this excellent Gotoh Telecaster bridge remaining (other items are sold):
Gotoh Vintage 4-Screw Mount/ Flat, Six Saddle Telecaster Bridge, Chrome Finish:
Gotoh Vintage 4-screw mount flat six saddle bridge, chrome plated finish. If I remember correctly this is the brass version of this bridge (GTC201), BUT I CANNOT BE 100% CERTAIN (I don’t have the original packaging). If knowing 100% that the saddles are brass or steel is critical to you, this probably isn’t for you (the bridge plate is made from brass for both versions). The bridge has vintage 10.8mm string spacing (2 1/8") and is designed for through-body string mounting. Comes with screws and height adjustment wrench. This bridge is a direct replacement for vintage bridge plates - it has the same mounting and string through hole patterns and is compatible with vintage spec Fender bodies, i.e. 10.8mm string spacing, 54mm E-e. Despite its modern looks this bridge will not fit bodies designed for 3 or 5 screw mount modern bridges such as American Standard models, or some Squiers.
£25 delivered.
Gotoh Tele Bridge, Gallery https://imgur.com/a/JNxfFEk
TV Jones Filtertron Telecaster Bridge, Vintage 4-Screw Mount/ Flat, Six Saddle, Chrome Finish:
TV Jones Filtertron Telecaster Bridge finished in chrome with mounting hardware. Not readily available in the UK, and generally in very good condition. This is made as a replacement for 4-screw mount/ vintage style bridges, though of course you will have to rout for the pickup itself. There is a slight blemish/ bloom in the plating in front of the saddles. It looks a little bit like nickel plating rather than chrome in that area – I’ve highlighted it in one of the pictures. It isn’t very visible once the saddles are intonated and the guitar is strung.
The blurb from TV Jones:
TV Jones pickups and Teles are like long lost lovers...anyone who has picked up a Fender Cabronita knows that to be the truth. It's almost unexplainable but there is something really special about ‘That Great Gretsch Sound’ exploding out of a slab of wood bolted to a 25.5' neck. Our Tele Bridge Plates are made in the USA out of cold-rolled steel and are specifically designed to fit Filter'Tron-style pickups such as our Universal or No Ears Mount. This plate comes with 6 adjustable saddles and everything you need to mount. This Original Tele Bridge Plate mounts with 4 holes.
Note: Original Vintage Gretsch Filter'Trons and TV Jones Filter'Trons have a clean 1/4 inch corner radius. Some modern Gretsch-style Filter'Tron pickups are made with more square-like corners and may not fit this plate e.g. Fender Fidelitrons and some others.
£45 delivered - SOLD
TV Jones Filtertron Bridge For Telecaster, Vintage Mount, Gallery https://imgur.com/gallery/brgNCfE
TVJ Bridge Slight Discolouration Highlighted https://imgur.com/a/3CI2BtA
Gotoh Vintage Kluson Style 6 In-lineTuners, Top Locking SD91MG-05M, Nickel Finish:
Gotoh top locking Kluson vintage style tuners for Strat or Tele. Dead easy to use, these tuners lock themselves as you tune (though a little additional gentle pressure with a coin on the top slot is advisable). Equally easy to release, again with a coin. The current version of these tuners has different sized holes in the posts (narrow for plain strings, wider for wound strings), but the version for sale here is the first version which all have the same size hole, and they work just fine. They also have 6mm diameter posts (not ¼” or 6.35mm) and come in the original box with matching bushes for both 8.8mm (vintage Fender) and 9.2mm (Fender reissue) diameter peghead holes, plus a bush removal tool and screws.
£25 delivered - SOLD
Gotoh Locking Vintage Tuners, Nickel, Gallery https://imgur.com/a/zJyFyue
Schaller Strap Locks, Original Style, Complete With Black And White Felts, Nickel Finish:
A complete set of original Schaller Strap Locks in nickel finish, including the strap buttons, mounting screws (plus an extra pair of screws) and a pair each of black and white felt washers to go behind the strap buttons. The extra nickel screws seem to be slightly thicker than the Schaller ones, but still fit through the buttons fine.
£12 delivered - SOLD
Schaller Strap locks, nickel, gallery https://imgur.com/a/CUw8m3d
Schaller Megaswitch Model ‘E’, New & Unused, With Both Black & White Switch Tips:
New and unused with mounting screws and both black and white switch tips, though I have written ‘E’ on it with fine marker pen so that I know exactly what it is. These are primarily designed for SSS or HSS guitars and provide the neck+bridge combination in the middle position of the switch (‘H’ tapped on HSS guitars). There are some diagrams for HH and HSH guitars too. Info and wiring diagrams on Schallers website:  https://schaller.info/en/megaswitch-e
£10 delivered - SOLD.
Schaller Megaswitch E gallery https://imgur.com/a/EU90GpE
