Esp Ltd Phoenix 1000.
Mahogany neck thru.
Mahogany wings.
Current: Duncan Sh-5 (custom).
Duncan Phat cat P90.
Heres the hard part. I dont dislike the sound. But my ear is a bit kak so this will be hard to describe..
I play with lots of gain, fairly scooped usually. Play at home, no band needs me to cut thru.
Mainly thru a Katana 100 2x12.
P-90 for the neck is fine, its in a humbucker size enclosure but I like the odd combination.
I use this for cleans.
Duncan Custom bridge, for gain. Metal tones.
For lead/soloing I just change amp channel to a similar setting as my rhythm but with more bass, a little louder and less treble and with reverb and decay.
Tis the way I’ve done it for ages.
I havent played much lately and I’ve had a few guitars come and go so this is where its not helping me lol.
Currently the Custom 5 sounds quite raspy, gritty, almost with a fuzzy element, like a muff.
Not obviously to that extent. But with high gain thats how I describe it.
Its probably not that bad tbh, maybe just a grittier distorted tone that I am used to.
Its quite thumpy/bassy maybe.
This is on the Katanas Brown channel, which I’ve used as the basis of my Distortion channels, then tweaked.
I have a feeling some of what I describe is just the nature of that channel. When I switch to the lead channel it does take a lot of the ‘thump/bassyness’ out.
I guess I need to get the laptop out and hook it up and spend a decent amount of time setting my presets up again as the last time I did this, it was for a guitar which had Emg 81/60’s.
Obviously I’ve had a tinker with the controls on the amp but not spent much time figuring it out.
When I say my ear is bad, well the guitars been set up recently, but I did lower and raise the bridge pickup today and I’ll be honest, I didnt hear much if any difference between quite damn low to probably too high..
I did test it out on with loads of gain though. Maybe on a clean setting I’d have noticed a lack of output at its lowest settings lol.. I also dont hear much of a difference when splitting it. On clean tones I do, distorted not so much.
All I really hear is less volume anyway when I do that.
This is what makes it hard, my ear isnt developed or knowledgable enough to pinpoint what I dont like or what exactly I’m hearing.
Maybe I do just need a good session with it and a tinker with the amp before going for a pickup change.
Are mahogany body/mahogany neck guitars darker sounding/bassier than mahogany/maple etc dya think? I did wonder if that was playing a part maybe.
My guess is that you've become aware of the harsh grainy inherent tone of the Katana - and once you've heard it, it's impossible to un-hear. I haven't tried editing one with a PC, but given how bad it sounded to me using the knobs I'm not sure there's a lot of point... I don't think it's a settings issue.
I know this might not make me popular with Katana fans .
https://static.roland.com/assets/media/pdf/BTS_KATANA_eng02_W.pdf
Active pickups are a lot tighter in the bass and with a crisper clearer top end than pretty much any passive pickup I’ve ever used: if your amp is still set for EMGs then you’d probably need to roll quite a bit of bass off. The other thing that a lot of modern metal sounds use is a booster or distortion pedal before the amp but with drive set to 0, just to tighten up the low end... again, you can do that in the Boss Tone Studio.
