The only string trees which have consistently caused me issues are the modern, cast Fender ones. The old style pressed ‘butterfly’ ones are fine - so long as they’re not corroded or excessively worn.
You do need to make sure it’s a good quality one with proper curved wings though - some cheaper ones are flat with sharp edges, and those do cause trouble.
I think by examining the upper surface of the wing section to ensure a ‘concavity’...? Which indicates a convexity on the string-contacting undersurface?
These ones okay?
https://www.ebay.co.uk/itm/Guitar-string-tree-7-5-mm-string-spacing-5-0mm-raiser-in-chrome-black-or-gold/371041120460?var=640217887697
Cheap ones are really obviously flat with sharp - and often rough - edges.
