Very fast and accurate tracking, and perfect for Lizzy harmonies. The only fiddly thing about it is that the controls are a bit cramped, and you need to dial in the correct key and major/ minor scale, and/ or interval, and under low light your eyesight needs to be good enough (mine isn't) but I've learned where the controls look and feel right, so it's not a deal breaker. Your singer has to be trained to talk waffly-bollocks to the audience for a few seconds while you set it up live.
The other thing the PS-6 is brilliant for is doing an octave below, which if you mix it in subtly and sparingly really fattens out a lead break quite tastefully. Completely at the other end, if you put the sub octave into a Big Muff running flat out, with oodles of delay added like a rich sauce, you get quite the most wonderful monster sound of supreme fuzzy gain heaven.
My music:- https://soundcloud.com/hubobulous
* or "Ab" if playing in a flat tuning... the results are like bad jazz if you forget to do this
Synyster gates uses an axe fx ii with several pre programmed patches, but I suspect the boss intelligent harmoniser is a really good compromise. Actually, pgs have a demo of it - watch the demo of the boss power stack, and they use one on it - sounds great!
Power stack sounded good to me too but was a bit noisy when it was up to higher than room volume
I used the harmoniser on a GT8 to play the second solo of "Show must go on" by Queen. I used the Expression pedal to bring the harmony in and out, then the Control pedal to change the interval. Sounded pretty good.
I still play "Show must go on", but have gone to a simple guitar and amp set up. I'm not sure anyone notices. But for Lizzy, you could really do with a wing man!
