Just wired my LPJish guitar up and no sound. I wasn't surprised as I'd made the harness!
What I eventually found was that if I pulled the jack plug out a millimetre or two it worked. I put this down to having used a stereo socket but that was all I could lay my hands on at the time of making the harness.
I'd since found a mono socket so swapped it over, tested it before putting it all back together no issues.
All back in place, no sound!
Pull the jack plug out a millimetre or two and it works.
Used three different leads same issue.
What is the problem? I'm sure it is very basic but I can't figure it out.
Thanks all... I confirm one way or the other later.
Thanks again
Simon
